WANTED...rear spring hangers
2 Attachment(s)
I have an 87 1ton dually cab/chassis. I am looking for the rear spring hangers and hanger brace..BOTH sides. here is a pic of what they look like. The PO flipped and welded them, was going to convert this truck to 4wd....I am lowering it. Thank You
Re: WANTED...rear spring hangers
wouldn't that be how you would want them? because that isn't going to do one bit of good for a 4x4....
:lol:They flipped the hangers over and welded them. I had to cut them into three pieces to get them off. And it only lifted it maybe and inch or two.
So you are looking for factory style rear spring hangers for the front position?
I should have what you need. Let me know and a zip code for a shipping quote and I will get you a price. Thank you, Thomas |
Rear hangers, rear position....along with the brace.
i have a set off a 91 square body 1 ton. $55 shipped if your interested. thanks. note: they will include the braces also.
pm sent
Are you looking for 1 ton 4x4 or 4x2?
Just bought what I needed from 396ci (Brian)......Thanks again Brian!
