73-87 lift/tire combo pics
Lets see some sick squares!! Post your 1973-1987 k series trucks with the following info,
-Size of lift -size of tires -brand of lift -full spring or blocks just so that people can see how the combos look and help them figure out wich combo they want to do! thanks!!:metal::metal: |
Re: 73-87 lift/tire combo pics
85 1 ton 8" bds lift all springs with 2" body lift 40x15.5r20
Those compact spares on the floor look like frisbees compared to your tires!
3" lift, 33x12.5x15, Rough Country, Springs front, blocks rear
6" with 35s seems to be as close to perfect as one can get imo
mix-mash
8" skyjacker fr springs & steering gear flips, blocks, & airbags, rr rough country shocks 39" swamps Attachment 1357236 |
Gmm that's a awesome looking truck !!!!!!
2 Attachment(s)
my 83 k20 4in lift 315/75r16 dynapro mt
Attachment 1357418 my 79 k30 3in lift 33x12.50r16.5 bfg at Attachment 1357420 |
4" rough country front springs, blocks in rear for now, 35x12.50r15 bfg mud terrains on 15x10 us wheels
Another pic
Take a look at http://67-72chevytrucks.com/vboard/s...d.php?t=348743
85 w/4" 35s
90 jimmy 4 inch springs 36x10.50 tires no clearance issues narrow tire.
Attachment 1357866 |
6" lift, all spring. 36" tires on 16.5" recentered humvee wheels.
http://fireandfuel.com/truck/truckpeach.jpg |
Front- 8" Superlift HD springs, ORD crossover steering
Rear- 4" ORD shackle flip, 1-1/2 block & zero rate New drivelines ( Inland Truck Parts, North Platte, Ne ) Toyo 38x14.5x16 wrapped on 16x10 Wheel Vintiques Truck rides and drives amazing! |
2 Attachment(s)
Just a 2" lift with springs up front and blocks in the rear with bags. 235/85/16's which is almost a 32" tire.
You guys are going to get me in trouble....
http://s27.postimg.org/jm707kw6r/231...0104_81109.jpg
That was with a 6" suspension lift, 3" body lift, Bushwacker Cut-Out Flares, and 38x15.50 Mickey Thompson Baja Claws. The rest are without the body lift. Without the flares, I had to trim the very corners of the front fenders a little. Otherwise they cleared just fine. I used a 16x10 wheel with 5" backspacing, for reference. With the cut-outs, the tires cleared by a mile with only 6" of lift. With the combined 9" of lift and cut-outs, I'm guessing I could have cleared narrow 42's. http://s27.postimg.org/n9mrdn4dv/0116002126a2.jpg http://s27.postimg.org/7f7v3rfn7/SDC10492.jpg http://s27.postimg.org/5ywclmcqb/Prom_3.jpg http://s27.postimg.org/mldwup5o3/Prom_5.jpg |
Your41Plague12
Do you have any close up pics of your fender trimming? I need to do mine. I would rather not have the wide flares as i run narrow tires. Any info would be great before i start cutting into good metal. Thanks, Chris |
Very nice Roy, great look :thumbs: |
Front = 2 inch tuff country spring with
rear = 2 inch blocks 33 BFG AT http://i1338.photobucket.com/albums/...ps7ea38702.jpg |
Keep Them Comin!
4 Attachment(s)
85 k20.
Skyjacker 2.5 in front with ORD front shackles. STL Spring 56" rear springs with +1" extra arch and ORD zero rate add a leaf. Bilstein 5100 all 4 corners. 285/75/16 Michelin LTX AT-2 on 16" GM HD powdercoated wheels |
