89 burb 10bolt in a 85 swb c10
Will a 1989 Suburban rear end bolt up to a 85 C10? The 85 has a Th350 and the drive shaft is 57in long. Will the 85 driveshaft ujoints bolt up to the Suburban rear end? Thanks for any and all help.
Re: 89 burb 10bolt in a 85 swb c10
I think it should.
should no problem, if u joints are different, its no big deal swapping them out.. mine as well since they are likely older than you lol
