68-72 Vent Windows With Soft Ray Glass
5 Attachment(s)
I removed this pair from a very clean 68 that I am parting out. I do not run across many in black that have the soft ray glass. This truck was very clean and the rubber around the frames is still very soft . The fuzzy in vertical channel should be replaced. The handles have a little pitting. The rivets on one of the lower mounts is a little loose. It will either need to have the rivets tightened up or new rivets. Very clean set that would be great for a driver . $100 plus shipping.
I also have the rear small back window and side glass in Soft Ray from the same truck but may or may not list due the fact that I cannot ship glass. I recently built a wood crate ($20)for a pair of 55-59 Chevy Pickup side door glass . Cushioned it with bubble wrap and expandable foam . You guessed it . Arrived broken . If someone is interested I will do local pickup. Sold Locally . Thanks |
Re: 68-72 Vent Windows With Soft Ray Glass
Sold Locally
How about the rest of the truck? Does it have the front windshield trim?
Thanks, Steve |
Window trim has been sold . Thanks
