What Engine do i have
/Users/Genaro/Desktop/IMG_5943.JPG/Users/Genaro/Desktop/IMG_5944.JPG
Re: What Engine do i have
your pics did not show up,try to load one at a time
Hmmmmmmmm hard to tell ;)
Judging from this post I'd say a greasy one:lol:
3 Attachment(s)
LOL sorry ok will do
You have a small block chevy;):lol:
Gotta get numbers! Don't once things are changed around it's usually impossible to tell without seeing numbers. Check the deck of the block, which is right in front of the pass. Side head. or on the bell housing! Post pics of those numbers! |
casting number is 3932388
Based on that, the block is a 68-79 GM 350 with a 4-bolt main. The stamps on the right hand deck might give a little more info, you might have to pull the alternator out to read the stampings properly.
Go to nastyz28.com and you can decipher each part number and all that! Great site if you like to know about the numbers!
Thanks guys for the info.
Small block Chevy with HEI distributor, sitting on six cylinder mounts, with the newer style long water pump front accessory setup.
Rubber hoses with a glass body filter resting on top of the exhaust manifold ... what you have
there is a fire hazard. :devil: And yeah. 1968-79 350. Could be two or four bolt main. Only way to be sure is pull the pan & look. |
