LS2 Custom Engine Cladding
This may have been done before, but it's the first time I have ever tried it.
A friend of mine asked me to "customize" the GTO covers for his LS2 engine. He is installing the engine into his '67 C10 fleet, and was looking for something different. He furnished two damaged GTO claddings for dissection and two new GTO claddings to modify. After many hours with the Dremel, Super Glue Plastic Fusion Epoxy, spot putty, sandpaper and semi-flat black here is the final result. The toughest areas to reshape was inside the "G" because of the slight curves. I would never do another set. Just too much time and patience which I don't have. POP |
Re: LS2 Custom Engine Cladding
Looks good. You should have someone pull a fiberglass mold off of them...:D.
That is pretty sweet.
Yep, fiberglass mold and sell those puppies
Great job!
those look so good!
if the truck intake manifold didn't flow so well I would have already switched over to that style intake so I could run the coil covers vs the top vortec cover that I have. |
If you get it molded. I will buy a set the second you contact me lol
I agree, very nice work.
POP |
Pop, those look great. Here is the set I did up for my brothers 69 Beaumont (Canadian sister to a Chevelle)
http://i1166.photobucket.com/albums/...e-Build342.jpg Did mine a little different than you did. Had a set of custom emblem rapid prototyped and affixed them with "emblem pins" |
I had to come in this thread just to see what "engine cladding" was.
LonghornSS, those look awesome! I love the color coordination with the rest of the truck. That is one cool LS2 engine. Nice work!
POP |
POP |
Man, those are some sexy covers! Did you cut the "GTO" out of the damaged ones to practice on or what was the reasoning for 2 sets?
Although she is not a Truck we take a lot of pride in showing her off. So here is an exterior shot. http://i1166.photobucket.com/albums/...e-Build366.jpg You can also check out more here if you guys feel so inclined. There are Also a couple of Truck photos on there of my Dad 65 C10 in a separate album. https://www.facebook.com/media/set/?...1262933&type=3 OK post takeover.... Over |
