How to Start a New Topic
Re: How to Start a New Topic
These are the codes available for use in your posts ( I used the php code box, so the tags would show.. otherwise you would just see the end result)
3 Attachment(s)
The following are using the standard editor ( you can select your editor in user options in your usercp)
This is the dropdown to choose the font you wish to use Attachment 1552207 this is the dropdown to choose the color you wish to use Attachment 1552208 and this is the dropdown to choose the size you wish to use Attachment 1552209 you can make your text huge and well just loud.. or normal and bold |
