5.5/7 drop kit questions (mainly bout the c-notch)
About to get a C-notch kit from CPP, and had some questions
Do I need to remove the upper spring plate when installing the c-notch? How much clearance should I get with the 7 inch drop in the rear? How accurate are the instructions? Ive heard of some of the 'reference holes' to be off. And if anyone has any pics of their 5.5/7 drop, post em up! |
Re: 5.5/7 drop kit questions (mainly bout the c-notch)
You will not have to remove the upper spring plate to install the C-notch. I'm not sure how much clearance you'll get on the 7" drop. The instructions are ok but lacking detail.
I traced the profile of the C-notch onto a piece of thin cardboard and used one of the bottom reference holes to determine how far back to locate the cut out. I oversized the cutout approx. 1/4" larger than the trace.
I bolted on the C-notch and also welded it into place.
My truck is 5.5" and 8" and I have no issues with bottoming out in the rear. I don't haul anything other than a plastic tote, chairs and maybe a cooler.
Good looking truck! What size wheels and tires are those?
and 18x8 up front. 255/55-18 |
That's my drop and I used the CCP notches also. I did it the hard way with the bed on because the 4/6 just wasn't enough and I had already painted.
It's pretty self explanatory once you get the notches in hand. Maybe a little massaging, but should be pretty straight forward. |
good info. I just ordered a load of goods from CPP and a handful of other places and had the same question regarding the c notch.
anybody running stock inner fender wells with there 5.5/7 drop???
