My Chevy 1500 W/T 94 V6
4 Attachment(s)
figured i would make my own thread for my truck
1994 chevy v6 4.3L 5 speed manual RWD miles 68 000 so far on my project 1=new suspension front and rear shocks 2= new ignition coil 3= new distributer rotor and cap 4=new front brake pads 5=4 new goodyear all terrain tires 6=new serpentine belt 7=new pulley tensioner and idler pulley 8=new spark plugs new HT leads 9=new batt 10= new alternator 11= full exhaust system "not installed yet" with flowmaster super 40 muffler 12= new door strikers 13= outer paint striped ready for paint work next year. 14= new fuel filter and air filter 15= heavy duty clutch installed new throw out bearing full kit. 16= all fluids flushed renewed including diff oil. 17 new stereo installed pull out cd player and bearcat cb installed. + 2 new rear speakers |
Re: My Chevy 1500 W/T 94 V6
issues on truck exhaust system is shot , new parts in box to replace soon enough, no ac system leaky line at condenser fitting replace next year.
may have to replace water pump and oil pump soon, might switch to high volume units not sure yet, engine runs good for now. need to replace rocker cover gaskets soon as well. new radiator hoses and thermostat need done, new temp sensor as well. need to fix and replace headliner,also sun visors. also a few dings one in bed still to knock out before painting and tail gate has a few dings, but apart from that body lines are great shape and rust free. |
i drive this truck everyday to and from work, even with the issues she's coming along runs very well on highway roads.
positives on this truck v6 is very good on gas , i have the 35 gallon tank installed. once up to highway speed she purrs along nicely at a steady 65 75 when needed. manual gears i love for the joy of driving imo. negatives slow of the mark granny gears 1 and 2. well this is manual not built for fast take off speed really. |
post cab picture shortly
2 Attachment(s)
cab is in great shape.
here's a small video me peeling the bad paint off this summer,
much of the paint was so bad it was easy to scrape off, some areas did require aircraft stripper ,great product. was a slow massive job to get where i am so far. https://www.youtube.com/watch?v=f9N05QV2nkA |
this little video segment u can hear the improved difference in engine
new pulley tensioner and idler pulley old ones where gone, bad bearings. https://www.youtube.com/watch?v=_VZY1hUvka0 hear the beautiful v6 idle now. |
little update
= new radiator hoses upper and lower = new thermostat = new dash sender thermostat = new engine thermostat |
= new aftermarket stock tail lights and circuit boards
=installed new third brake light led :metal:
4 Attachment(s)
here's a few night pics of new third brake and cargo light, really am impressed with this light.
= new duralast water pump and fan clutch ordered
I like the black gloss grille. I painted mine a bright silver with clear. I like the old seal beams too, they never yellow
http://i1198.photobucket.com/albums/...psnfexbam9.jpg |
wish i lived near u cape help me paint my truck bud.
new exhaust finally on and welded with flow master super 40.
https://www.youtube.com/watch?v=K0p16xoPUbo |
3 Attachment(s)
some pics of the exhaust install.
truck is very clean underneath, those cross members are only light surface rust yet to be jet washed off.
some new front lights and led bulbs
next is new water pump heavy duty type, new radiator, new ac condenser and ac lines install.
5 Attachment(s)
new water pump heavy duty type installed , new fan clutch, new radiator
oil cooler outlets capped off, new ac lines , new ac condenser installed.:smoke: |
Looks great! I'm a big fan of ac, especially in July and August.
Looks great! Keep at it!
thx guys...
