List of Frame Bolts?
Does anyone have a list of all the frame bolts probably grade 8 that would mount to all the cross members, cross member pieces/mounts to the frame, transfer case member, side transfer case mount, tranny, etc? Basically, any grade 8 bolt that would go through the frame and/or a cross member, a count of how many would be helpful as well.
Let me know how I can be more descriptive to get the answer I am looking for. I have a 1971 K20 4x4 LWB with SMB 350, TH350, NP205, Dana 44, Eaton in Rear. This would be very helpful. Thank you! Rex |
Re: List of Frame Bolts?
LMC lists a Frame Hardware Kit, p/n 30-1146. Never used it so can't comment on it, but it's listed as grade 8.
dont know how many is needed , but I do know tractor supply sells grade 8 bolts by the pound, and is lot cheeper then most places that sell grade 8 bolts by price per each bolt, So if you are close to a Tractor supply store I would go there
Thanks for the help. I'll give tractor supply and check LMC
I heard the bolt size I should use is 7/16 20 x 1 inch grade 8 |
7/16 20 NF is fine thread. 7/16 14 NC is what you need. Do not use a flat washer under the lock washer and hex nut. You want the lock washer to bite into the part and nut.
They do not supply the 7/16 in grade 8 down here in north dallas. I have a couple more hardware stores here but more expensive than 3.99 a pound. |
7/16 14 x 1 inch grade 8 + lock washer + frame parts + lock washer + 7/16 grade 8 nut Or do I need lock nut as well. Thanks for the help |
Anyone know the bolt size that comes in the lmc kit online it doesn't show or have this information. Thanks |
Are you cutting all the rivets out to replace with bolts? Most of the pieces you described, like cross members, are rivets to the frame from the factory.
Gary |
Or do what I did and skip the washer all together and use flange bolts and flange prevailing torque nuts(metal lock). I ordered mine from bolt depot. Your best bet on actually getting an accurate list of bolts needed is to count whatever you plan on changing and make up a list, or just order a bunch of the common sizes and keep the extras and put in your bolt bin. A bunch of 3/8 and 7/16 will get you along way, atleast it did on my c10, maybe a K20 has less 3/8, never worked on a K20. |
I have to ask why are you bolting your frame together ?
Tractor supply doesn't carry 7/16 grade 8 hardware . If your bolting the frame back together don't pinch pennies buy the best available . |
Yes. I agree not to trim the budget here. I just want to make sure I get the right bolts. What are the best brand / quality bolts. All I would think to get is the grade 8 and didn't matter the brand. Just yellow zinc . |
Gary |
Use red loctite instead of lock washers on the frame -- lock washers are actually detrimental contrary to popular belief (according to NASA, there's a thread on here somewhere with a whitepaper link).
You will want to use a bolt that is not threaded all the way to the head. It should be a very snug fit. If you don't, it will be difficult to keep aligned.
