My 85 C10
Hello Everyone, I am in the middle of an ls swap on my 85 C10.
Tons of parts purchased... Needs body work like a dead man needs a cofffin. But here we go. So far, Here's somewhat of a parts list... '98 LS1/4L60e I have had complete sitting in my shop for 12 years or so. (also have an L33 & a 4L80e I may throw in the truck instead) 1 set of 243 heads & 1 set of 799's at the machine shop getting cleaned up. Plan in ditching the heads on the LS1 currently. Lokar LS1 48" throttle cable Lokar throttle cable bracket-billet Part #TCB-40LS1 Tejas Metal Works transmission mount (Will be switching from the Dirty Dingo motor mounts to Tejas Metal works) Drive shaft was made at DriveTrain of Mesquite in Mesquite Texas PSI engine harness for LS1/4l80e 411 PCM, ditched the '98 PCM Lunati double valve springs Comp Cams pushrods Lokar billet column shift arm kit Part #ACA-1800 Spectra Premium 31 Gallon tank for an 87-91 K5 Blazer or a Suburban Part # Spectra Premium Sending Unit Part # Walbro intank pump Corvette Filter/Regulator Used a mix of Earls&Russel fittings for -6AN fuel line Taylor 9mm Spark plug wires NGK Iridium Plugs Pace Setter long tube headers for 98-02 Body Wheels-22" Coys Pirelli tires 265/35r22 on the front, 285/35r22 in the rear. DJM drop spindles/coils front, flip kit rear (Competition Specialties Triangulated 4link with coil overs going on the rear soon along with Ridetech control arms Upper&Lower) |
Re: My 85 C10
5 Attachment(s)
I guess some pics are needed!
Attachment 1598202 Attachment 1598203 Attachment 1598204 Attachment 1598205 Attachment 1598206 Ls1/4l60e are in the truck. Need some opinions on adapting the 4l80e to the LS1. I know Circle D have stalls available, but I believe the stall speed is only up to 3000rpm for their 278mm. |
Re: My 85 C10
5 Attachment(s)
Attachment 1598207
Attachment 1598208 Transmission crossmember Attachment 1598209 Ebay billet steering wheel Attachment 1598210 Fesler billet lock knobs Attachment 1598211 Lokar Billet throttle cable bracket |
Re: My 85 C10
5 Attachment(s)
used 2 Earl Fittings to adapt to the two Metric fittings on the feed & return ends of the sending unit to -6AN
Re: My 85 C10
3 Attachment(s)
Attachment 1599417
Attachment 1599418 Attachment 1599419 Removed these center hood hinge springs. Started installing these hood struts from Wamrods!!! Awesome product! |
Re: My 85 C10
Attachment 1599598
Notice the cable end of the rod. To use the Lokar throttle cable with the clevis end, the split at the end could be a problem. It also wont work with it running parallel with the firewall. |
Re: My 85 C10
Attachment 1599599
Heated and pinched closed |
Re: My 85 C10
Attachment 1599604
Heated and twisted |
Re: My 85 C10
2 Attachment(s)
Attachment 1599605
Attachment 1599606 I'm using the 48" LS1 throttle cable, I can't remember which part number it is. Later on, I'll install the billet pedal. Part #BAG-6165 |
Re: My 85 C10
2 Attachment(s)
Attachment 1599608
Attachment 1599609 Removed the junky two piece transmission crossmember. Installed the new one from Tejas Metal Works. I'll get some pics soon showing it from underneath the truck. |
Re: My 85 C10
Re: My 85 C10
2 Attachment(s)
Got most of the way through installing the Wamrods hood strut kit. I still have to make small notches in the hood for it to close. Followed the directions with the kit, and drilled three 5/16" holes into the fender. Measure more then once! Luckily I have small hands and wrists but if you don't, mounting the pieces to the inside of the fender are difficult.
Attachment 1600003inside the passenger fender looking down. Attachment 1600004looking at the passenger side of the hood towards the cab. |
Re: My 85 C10
looks like youre getting it knocked out! keep it up!
Re: My 85 C10
Trying too! Working 30 hour shifts and off for 18 hours with no days off this year has really killed me having much time haha. Hopefully I'll have everything put together by the end of January. I plan on taking it all apart after that and having the frame and tons of other stuff powder coated in Hobbs, New Mexico.
I am going to try and knock out most of the body work while the frame is there then get it all back together. |
Re: My 85 C10
Posted via Mobile Device |
Re: My 85 C10
I finished up the Wamrods hood strut kit install today. Well worth it!
Re: My 85 C10
Re: My 85 C10
5 Attachment(s)
Re: My 85 C10
Not sure how my pics came out sideways
2 Attachment(s)
Went with a 278mm Circle D 4l80e 3000-3200rpm stall convertor. Got it in about 3 business days. Looks amazing!!! Excellent customer service
I also ordered a TCI flexplate that is dished like the ls1 flexplate and the convertor is made to fit the flexplate of the ls1/4l80e. Part number for the flexplate is #399753
2 Attachment(s)
I decided to go ahead and get the billet throttle pedal from Lokar while I was ordering parts.
4 Attachment(s)
I have been working 2 weeks on, 1 week off here more recently so I have a little more time now to plan ahead and work on the truck. My Circle D stall and TCI flexplate arrived during my 2 weeks on at work. Getting everything planned ahead to pull the 60e out and put the 80e in. I ran some fuel lines but one of the -6AN push lock fittings for the fuel rail didn't work so I had to order a different style of Russell's fittings. I test fit the 98-02 fbody efans to my 4 core radiator and started wiring up two relays. The wiring is temporary, I want to see if the efans work and still undecided on where to stick the efan relays.
Before I get started running wire for the fuel pump to the K5/Suburban tank. What size wire should I use? I believe the amp draw of the walbro 255 fuel pump is somewhere around 10-15amps. If anyone could please help me out here, it would be greatly appreciated! Posted via Mobile Device |
Here is one of the 243 heads with Lunati dual springs, milled a tiny bit amd new valves.
