WTB 14 Bolt Semi Float Differential
Looking for a 14bsf out of an '81-'87 4x4 3/4 ton, preferably with 3.42 gears and 11 inch brakes. Bonus if its out of a 4 speed truck so I can also get the driveshaft.
Please let me know what you have. Thanks, Danny |
Re: WTB 14 Bolt Semi Float Differential
With the 10.5" ring gear? I'm looking for the 9.5" ring gear differential as I'm trying to upgrade my 1/2 ton and keep 6 lug wheels.
Are you still looking for this rear differential? I might have one. Have to pull the cover and check the ratio and check the brakes. It came out of an 86 GMC 2x4. Thanks, Ken
Sorry for taking so long to get back to you, I'm in the middle of moving to GA.. I've already found one. Thank you though, Danny |
OK, glad to hear it. Shipping would have been a monster on that anyway. BTW, did I understand your post to say you can put six lug axles in this rear end? Thanks, Ken
It's my understanding that there are two ways to get a 6 lug semi floater. Re drill the shafts and drums on an 8 lug to 6 for a squarebody housing which is what I intend to do. Or find a 6 lug version out of a GMT400 truck and move the spring perches and shock mounts. Since I can't weld I figured it would be easier to get a squarebody housing and take the drums and shafts out and have a machine shop re drill them for me.
Thanks, Danny |
OK Dan, Thanks for the clarification.Ken
I have a semi float 14 bolt 4.10 13" brakes in Spokane Washington
Here's some axles:
https://lansing.craigslist.org/for/d...399412056.html |
