Front Spring Hangers
Does anyone make these or something similar for 67-72 trucks?
Re: Front Spring Hangers
You have to run 52" springs with those, right?
ahh, ya i think so. I think the stockers would be too short for the rear most holes on those brackets. Not to mention, there should be a cheaper solution for you as well. Sry... I know there was a company carrying stock replacement brackets for square bodies and earlier but it's been so long I don't remember who it was.
These were just posted
http://67-72chevytrucks.com/vboard/s...d.php?t=746811 |
Thank you
I'm needing a set also, may have to do the 52" set-up...is that what the squarebodys had was 52" springs? Just wondering how much more cash I'll have to shell out if I go that route. I bought a truck that has been put in a ditch on passenger side and twisted and tore the front passenger spring hanger.
I don't think you "have" to run 52s with that kit, I wanna say using stock 47s will move the axle forward 1". I had a set of these on a 2wd crew that I converted to 4wd, and used stock style 4" 47s. You don't have to do much just to run 52s. Mainly moving the front mount forward.
FWIW, 52s aren't a big deal to install either. |
subscribing
Digging up an old thread....
Do not believe the B52 brackets interfere with the bumper. Side braces will bolt up just like stock in the radiator support section. May be able to use the longer 73+ front springs with the brackets for a stock like height. Think it was mentioned the furthest back bolt location is about 1" froward from stock.
52" never came on the front of Chevy 4x4's. Off the shelf you will have to use rear springs. They will have more arch and will add 4"-5" of lift with the kit. If you want lower custom springs are the only option with the brackets |
Looks like I might go with Sky's Drop Perch instead. |
If you weren't putting the spring in the front hole, you could cut the DIY perch and leave the bumper alone. I needed the front hole to make it all work so I just started over with Alcan springs.
