1958 Apache Big Window Loooooong Bed "Lucky"
4 Attachment(s)
Hey Gang,
This stray truck followed me home yesterday. I was a self-described longbed disliker, but this one got me! Original paint (turned out it was just repainted the same red), little bit of aftermarket bondo, very little cancer. The Good: Floors are solid!! Steps are solid!! window areas all solid! Hinge pocket seem solid, need to be cleaned out One corner not rusted through Original 283 still there, turns by hand when i turn the fan, oil in the block still 5 new spark plugs in the glove box. The Bad: Was hit in the drivers front, everything in that area is tweaked / off a bit Previous owner resolved the resulting door fitment issues with a hammer until the door opened again The Interesting: No less than 20 wasps nests in there Bench seat was replaced with a seat from a school bus and used like that for years Rubber bumpers added to the front grill (why?) and the dangling horseshoe gives the truck its name. Plans:
Please respond with excellent links for me to get this truck on the road safely! I can't seem to find a thread that journals a simple "get er going" process...(I've learned why-nobody ever stops there) |
Re: 1958 Apache Big Window Loooooong Bed "Lucky"
3 Attachment(s)
more photos
Man that looks like a sweet start to a truck! I think you'll find a few threads would love to have been "get her going" and turned into big snowballs of a rebuild. My truck started with a get-er-goin' mantra and I was able to get the 235 up and running. The next step was much more difficult and that was to get her safely to home depot and back for the envy points.
The problem you may find, as I did, is a truck that sits will have lots of issues with cracked and aging rubber and wiring. Check under the dash and in the door for those lovely nests. I had a giant one behind the dash and it covered the steering column. Awesome! Rust will also be an issue with trying to get things moving like working brakes, parking brake, etc. How does it look under the hood? Maybe start with tires? Working headlights? lol |
need close up and high definition pictures of your neighbors scowls when they see it hahahaha
nice score! if I were your neighbor I wouldnt scowl! |
The bumper guards and scratches on the bumper make me suspect that it was a service truck for a shop, or a service station back when they actually provided service. The rubber covers probably went from top to bottom to keep from scratching the bumper on the car being pushed. We had a section of tire on ours back in the fifties.
As for what to do to it first, the old saying is make it go, make it stop, make it legal. After that you can mostly pick and choose what you want to do next as far as appearance and comfort items. You have a BBW and the dash hasn't been mutilated in the radio location so that's a good thing. |
Nice looking start. It is in alot better shape than my longbed was to start with.
I figure right off the bat it will need: Hoses fluids brake shoes anything made of rubber likely replaced Spark components new gas tank out back and fuel lines (if im buying a new tank, might as well right?) Wiring updates/corrections carb tuned or replaced PB Blaster bath and probably 100 more things. |
After driving the Jackalope for 4 years, I'm just spoiled now and insist that my trucks be all original paint and body. |
2 Attachment(s)
No new truck photos yet, but I picked up a (supposedly) running 283 from a Chevelle pretty cheap, and its rated up to 220 so thats an easy kick in the pants for Lucky without breaking the bank. It also came with extra 327 heads (which I wont use, anyone in Norcal need 327 heads?), an extra 327 intake, and an Edelbrock 1404 500cfm carb.
Carburetion is a whole new world for me, by the time I got a drivers license everything was fuel injected. "Doing it right" and having everything machined, hot tanked, etc. is great, but I think I'll be dropping this in as-is and seeing what happens. If it's garbage, that just means more chances to learn!! Are there any reasons I should try and fabricate side mounts instead of using the front mounts? Is it worth the trouble? |
Took apart the front brakes today and even though the steering wheel turned the wheels with no trouble, I couldn't move the spindle by hand easily. Is this a sign that the kingpins need replacing? I assume that a truck sitting out in a field may need this done anyways.
Replacing the king pins is a good idea if the spindles don't move freely. It will steer rather erratically with them stuck.
Thanks, I'm going to go ahead and order the kingpins to go along with freshening up everything else. Learning so much!!
So, i've been comparing the prices to redo the drums vs. a disc brake upgrade. Here is what I have so far: Drums- 90 new lines- 25 new wheel cylinders-40 new master-100 shoes-35 roller bearing upgrade- 95 Total- $336 Vs. a disc conversion kit, which is ~$700 from my local shop and includes everything plus a booster. OR $400 without the booster/master cylinder locally, and I supply my own master cylinder. Is the booster necessary/worth it? |
2 Attachment(s)
As all projects do, plans for mine have grown. I decided to go with the Flatout Engineering C4 IFS, and I've gathered the necessary Corvette parts.
I got stalled with the crossmember rivets and planned to burn them out, but I figured out a safer way to deal with these... Removing Frame Rivets: 1. Cut a + in the rivet head with cutoff wheel on a grinder 2. stick a freshly sharpened cold chisel into some vise grips to keep your hand clear. 3. Beat the hell out of those rivet heads with a 3 pound hammer until they shear off. Now many people were able to just punch out the remaining half of the rivet..but not me. Lucky wants me to earn everything. 4. Drill a small hole until you pass the depth of the riveted on material. - Some of the rivets were not easy to reach directly with a drill. I still drilled these out. I drilled a hole at an angle, and started the small pilt hole closer to the edge of the rivet. 5. Using progressively larger drill bits, I drilled out most or all of the rivet from the crossmember/leaf perch. You can tell you have reach the bottom of the hole left from the smaller drill bit because the bit spins faster suddenly. 6. Using a punch clamped in vise grips, beat out the remaining section with the 3 pound hammer. I got all rivets out this way! Super stoked that I didnt have to cut any out with a torch. |
Plans always seem to evolve and grow, as does the cost ha ha :D
looks like a nice truck to start with though. looking forward to seeing it getting done. |
2 Attachment(s)
Grinding the head off from below was a little painful until we covered ourselves head to toe with clothes/towels. But after that, it went fine. (Mostly my brother-in-law did the grinding and I did the whacking from above!:lol:) I used the big diameter punch in about the middle of the picture. |
3 Attachment(s)
Spending bits of time here and there to get Lucky ready for the Flatout Engineering C4 IFS Crossmember.
After hours of wire brushing, rivet removal, grinding, etc., I was finally able to trim down the frame to accept the boxing plates. The bottom of the frame flares out to accept the stock crossmember, but it needs to be flush to accept the crossmember. First I positioned the boxing plate to determine where it will sit to be 90 degrees from the top of the frame. Next I used scotch tape to lay out a straight line that has a high contrast. Pulling the tape tight ensures I get a clean line to cut on. Then I used a cut off wheel to remove the extra. I started by making a shallow score along the line, since less cutting meant more control. I could then go over this shallow cut with multiple passes, creating a nice groove for the wheel to follow. Once it was deep enough, I could run the wheel straight through the groove and cut off the piece. I don't own a plasma cutter so I'll have to keep making messes with the cutoff wheel. Question for anyone who has done this IFS before... should I notch the boxing plate and frame to accept the steering rack notch before or after I marry the plate to the frame? Without a plasma cutter it seems like it would be a huge hassle once its on the truck. |
I also found a 5.3/4l60e/ecu/harness/pedal for $1k and its waiting patiently to cause my budget to increase.
Got back into the garage finally to get the trans cross-member out, clean up the frame some more, and start figuring out where this Flatout C4 cross-member needs to go.
In case anyone is removing the trans cross-member with the cab on, here is how I removed mine: I used a Reciprocating saw with a long blade to cut out the bulk of the cross-member. Then I trimmed the remaining pieces with the recip saw. I couldnt cut it clean off so I cut through most of it, then used a pry bar to bend them out and off. It wasn't easy. Then I had enough space to cut off the tops of the rivets closer to me with a cut off wheel. More bending and hammering and i could get the remaining pieces to pop off of the rivets, using the cutoff wheel when needed. Then I could easily cut off the rivets for the leaf spring perch and hammer that down and off the frame. QBRacing is building his ahead of mine and he went with 28.75" from the frame end to wheel center on his 58/59 flatout front install... Does wheel size make a considerable difference in this measurement? QBRacings build thread I also need to get these boxing plates figured out, as they seem to box well behind the crossmember and not very far in front... just to box around the c notch that I need for the steering rack will require some trimming most likely. Is there a structural reason for this? Also how do yall add frame paint behind the boxing paint? doing it before might contaminate the welds... doing it after seems like a huge pain. |
Crossmember located and tacked in.
Update:
Despite this being a weekend job, my double, triple, quadruple checking combined with being intimidated has stretched this out a bit. At some point I chose to start learning from mistakes again and dove in to get the front suspension set up. I boxed up the crossmember and trimmed the boxing plate so it could be moved forward and box around the c notch completely. I didn't like how it looks partially boxed, and the boxing plate ending halfway doesn't add as a much strength in my mind. I got the wrong crossmember from Don at Flatout, but he and I found a solution that was the most cost-effective and would save us time... I find a 96 suspension setup instead of the 86, and he's going to send me a rear kit and shave a few bucks off, so....... We are going full 96 Vette! I got a front and rear setup for $650, and I need to sell the 86 front now. Frame is boxed, notched for the steering rack, and crossmember is tacked in. http://dshillingphoto.net/photos/201...04309small.jpg Taking one last look to make sure the wheel is where I want it before the crossmember is burned in. http://dshillingphoto.net/photos/201...03544small.jpg This photo reminds me that it will eventually look like a truck again! http://dshillingphoto.net/photos/201...04337small.jpg |
Dave
Looking good, strong work!!!! How did you establish ride height? Going to be using Flatout C-4 frnt and rear. one my 57 GMC just as soon as I can get my shed done, you know living life has it way of getting in the way. Keep on keepin on NC :clap::clap::clap::clap: |
I was also a non long bed lover. I don’t have any references but maybe I have a couple inspirational photographs of long beds. These two Have changed my mind.
Whose blue truck is that Dan? I've see it numerous times, in photos, and it's really nice.
Ride Height is pretty much set in stone with this kit unless you do more fabrication. I leveled the crossmember with the front 2" lower than the rear. |
