Hard to steer when breaking
Right after I rebuilt my front suspension with new power steering and power brakes (Drum/Drum) I’ve noticed that it’s hard to steer my truck when I’m coming to a stop or slowing down. I did not do hydroboost so that is out of the question.
For example: going 30mph and when I need to turn into a driveway, I’ll start slowing down and when I’m at a decent turning speed and still have the foot on the brake pedal, the steering wheel will be really really hard to turn. As soon as I let go of the brake, it turns smoothly. I have a feeling it has something to do with the brake pads in the front drums or maybe I let something loose on the suspension...what do y’all think? |
Re: Hard to steer when breaking
I'm voting on something loose in the suspension/bearings, after that brake pads/drums. I'd get it up on safety jacks and check for "any" play in the steering (box or links) then your wheel bearings, brake pads, drums.
Besides it will give you confidence. |
does it pull to one way at all when you apply the brakes. it may be a brake hose giving you a problem
ron |
Are you running hydroboost? Its a semi common symptom when first setup.
I took a look under and my center link is too close to the subframe that is right under the enfine. I’ll take a closer look today and see if that is what has been running and keep y’all updated.
If it is that, then I have a feeling the wheels travel back jusr slightly so that the center link touches the subframe and makes steering difficult. Because as soon as I let go, it’s back to normall. |
ron most of those centre links are close to begin with |
make sure them rear drums are adjusted and working good. I had that issue when I first got mine
"as soon as I let of the brake pedal" as in hit the gas again? Then I would say the steering pump is turning to slow at idle (on the brakes) to assist the turning properly.
Adam |
Update, there’s no suspension linkage rubbing anywhere.
I did notice the other day, leaving through a steep driveway, it seemed to also be stiff to move the steering wheel. So my next thing to do, is to drive the truck up a curb or something where the wheels will all be different elevations. Then crawl under while someone tries to steer it and see what is happening. Any other theories y’all have jusr send them my way. |
ball joint binding?
