Back up lights?
Hello I’m fairly new to these trucks and no where near a mechanic. So I bought a ‘67 GMC SWB that had the original three on the tree moved to the floor. While attempting to get it inspected the reverse lights don’t engage. How do I correct the wiring to the new shifter to make the truck legal?
Re: Back up lights?
Do you know what brand shifter it has ? Hurst makes a separate switch mounted to the shifter body . :chevy:
https://www.summitracing.com/parts/h...SABEgKicPD_BwE |
Re: Back up lights?
Yessir, it’s a hurst shifter
Re: Back up lights?
It might be easier to just put them an a toggle switch under the dash,just run the hot wires to a switch and voila.
Re: Back up lights?
lokar makes a few different reverse light switches. I'm running one now that once adjusted correctly works perfect.
