1969 cst 10
$13,000 or best offer. I do not want to trade.
I've owned the truck since 2000. Selling only to fund another project. I Truck will be sold with a bill of sale. Truck is currently registered and driven. Body- truck does have rust in rockers, bottom outer skin of passenger door, kick panels and on the drivers side bed. body is straight, and the truck has been in GA all it's life. Engine- 385 cubic inch small block Chevrolet estimated 500 horsepower 10.4:1 static compression- runs on 93 octane 4.040” bore 2 bolt main 350 block, align honed main caps Balanced rotating assembly, Assembled with ARP main cap studs and rod bolts Eagle 3.75” stroke internally balanced crankshaft Eagle I-Beam connecting rods Clevite rod and main bearings Speed Pro Flat top pistons 6.75” harmonic dampener Melling M-Select Oil Pump, ARP oil pump driveshaft Howards Rattler Hydraulic Roller Camshaft- 235 in/243 ex duration, .530” in/.530” ex lift 109 LSA Howards Roller lifters Cloyes double roller timing chain Profiler 195CC intake runner aluminum cylinder heads 2.05” intake valve, 1.60” exhaust valve, straight plug, 64CC chamber, 7/16” screw in studs with guide plates, ARP head bolts Comp cams hardened push rods Comp Cams ultra pro magnum roller rockers Edelbrock Performer EPS Dual Plane aluminum intake Davis Unified Ignition(DUI) HEI distributor, custom built for truck Canton 7 quart oil pan with baffle and windage tray 750 Vacuum Secondary Holley HP carb custom built for truck, 1” phenolic spacer for carb Holley 110 GPH fuel pump, custom throttle linkage Clear Image Stainless Steel 1-3/4” primary long tube headers that do not hang below the frame rails 3” exhaust, flowmaster 1 chamber race mufflers. Will update pictures tonight and provide sound clip Serpentine belt drive from mid 90s Chevrolet Silverado. New alternator New Water Pump New Starter Champion 4 Core Aluminum Radiator SFI approved flywheel Transmission-Turbo 350 Automatic Hughes 10” 3,000 RPM stall converter B&M shift kit B&M Cast aluminum Deep Pan with cooling fins Lokar shift linkage Rear axle- Stock 12 bolt, 3.08 gears, no posi Chassis, Steering and Suspension- 2.5” front drop spindles Power disc brakes New upper, lower ball joints New inner and outer tie rod ends New upper and lower control arm bushings New idler arm New pitman arm New power steering box 4” drop rear heavy duty coil springs with new spring perches New Bilstein Shocks front and back Adjustable panhard bar Rear drum brakes have been rebuilt 15”x10” wheels with BFG 275/60/15 radial t/a tires Interior Autometer Phantom Gauges in Stock housing- Speedo, Tach, Oil Pressure, Water Temp, Fuel, Volts, and Trans temp. LED turn-signal and high beam indicators new heater/defrost/blower controls new heater blower motor new heater core Mid 2000s Silverado second row bench seat, original seat is available to buyer if they want it. New rear wiring harness New underhood wiring New Sylvania silverstar sealed beam headlights https://scontent-atl3-1.xx.fbcdn.net...21&oe=5DAED234 https://scontent-atl3-1.xx.fbcdn.net...c3&oe=5DAE37A6 https://scontent-atl3-1.xx.fbcdn.net...4d&oe=5DECE75C https://scontent-atl3-1.xx.fbcdn.net...b2&oe=5DA47ED8 https://scontent-atl3-1.xx.fbcdn.net...ea&oe=5DA90AE1 https://scontent-atl3-1.xx.fbcdn.net...06&oe=5DEE96AD https://scontent-atl3-1.xx.fbcdn.net...fb&oe=5DAC52B7 https://scontent-atl3-1.xx.fbcdn.net...db&oe=5DE5CC3C https://scontent-atl3-1.xx.fbcdn.net...79&oe=5DDF19E6 https://scontent-atl3-1.xx.fbcdn.net...26&oe=5DACE8AE https://scontent-atl3-1.xx.fbcdn.net...dc&oe=5DE165A3 https://scontent-atl3-1.xx.fbcdn.net...30&oe=5DABA4EB https://scontent-atl3-1.xx.fbcdn.net...57&oe=5DA1DBB9 https://scontent-atl3-1.xx.fbcdn.net...cf&oe=5DE1B60F |
