WTB: parking brake guide
I'm looking for the rod that mounts to a slot on the frame on the passenger side close to the transfer case that holds the ebrake cable as it bends around and the cable goes along the frame rail into the rear cable that goes into the drum backing plate. please see pic. I think its called the parking brake guide? 1972 K10. thank you!
Re: WTB: parking brake guide
I have a few they are about 12" long
2 Attachment(s)
they are easy enough to make here are the sizes if it is a 1st gen Blazer. Not sure if all 4x4 are the same. The top one is the one you inquired about. It is just 5/16" diameter rod bent both ends
