Installed my Amazon LED headlights....
3 Attachment(s)
I've seen these "cheap-ish" LED 7" headlights on amazon for a while now... I though i'd give them a shot... First off let me say they are WELL BUILT... very heavy duty and they have a good feel to them... great light output and don't look too bad if you ask me... i am very impressed so far!
Re: Installed my Amazon LED headlights....
Need some night pictures to see how they look sir! The do look nice though.:chevy:
plastic lenses?
I was wondering about these as well. I would like to see how they look at night
Is that a 120 volt plug at the end of the wires?
did you notice availability on the GMC headlights?
Those look a lot like the Rigid Ind. that I paid over 5 times as much for. I really like mine, but I will say, if you drive in snow or freezing wet conditions, you won't like them. The Rigid Industries model that I have are equipped with heated lens to keep snow and ice from blocking light output. Those appear to be similar in design and the light output is by far the best you can get with just two lights ! Hope these treat you well
https://www.amazon.com/Headlight-App...xpY2s9dHJ1ZQ== |
2 Attachment(s)
I got these in today for my gmc from octane lighting as soon as the weather cooperates I’ll work on getting then in
Hey OP.... How are these lights working out for you?
For those wondering the same lights from the same vendor are available in 5 3/4” for us GMC guys. A 4 pack cost me $160. I will have mine today and will see about install this weekend. They are an H4 plug.
Pics update please... I would like to see what they look like. Thanks
I am also interested in how they look at night. And how the cut off at the top looks.
Link below to a review I did on 5 3/4 LED"s with pics way back in 2018. May be helpful for the quad headlight/GMC folks. The only thing I will add is though the headlight relay harness is a great idea, it's not required if you are going to an all LED headlight setup.
https://www.67-72chevytrucks.com/vbo...d.php?t=755421 |
2 Attachment(s)
I wanted to see a real life pic of them on....but here's from the Amazon listing. they are still on there..looks like the same brand too
7 inch LED Headlight Round 2PCS E-MARK Approved 6000K Hi/lo Beam lamp, UNI-SHINE,J004-2pcs https://www.amazon.com/dp/B0796QHYSR...ing=UTF8&psc=1 |
Are they DOT approved?
Funny enough... I had these in my Amazon wish list since 2020.
Very interesting. I see Holley has come up with their own line of these, which includes 3 different color themes depending if you like yellow, original, or a more modern white.
They want $200 per light. https://www.holley.com/products/exte.../parts/LFRB135 Photo of their 3 colors. https://images.holley.com/round_3wide_lit.jpg |
$400 a set?? Jesus they do look nice though. I like the full light pattern on those compared to the Amazon ones. ..but not $400 like lol
TECHNICALLY... to be DOT compliant and pass FMVSS title 49, part 571 (section 108) they also need to have SAE standards testing completed and be stamped with the SAE testing section. These do not have that. Basically China made is stamping DOT on them. So are they "DOT" approved, no. As technically the DOT does not test ANY lighting coming into the US unless there is an issue brought forward after the fact that causes it. The DOT posts the requirements the manufacturers have to abide by and SAE keeps them in compliance. |
