QA1 Coil Over System
Has anybody installed the QA1 Coil Overs in there 67-72. If so ,Did you have any problems and most of all How do you like it
Thanks |
Re: QA1 Coil Over System
Yes I installed that system on my 69. I really liked the way it installed and I also put the rear sway bar on. I also installed the front system also with the sway bar. I am still in the process of building my truck again, so I have not been able to drive it yet. It installs very easy. The rivets are not to bad to remove.
Wally |
Would you have any pics of the install? Steve |
4 Attachment(s)
I am using a 69 Camaro tank and have no clearance problems. The only thing I have not worked out is the exhaust. And I am still using my 12 bolt out of a 72.
I can’t get the pictures right. And I don’t have the gas tank back in yet. |
Thanks |
2 Attachment(s)
Here is two more pictures and there is 1 3/4” between the bar and rear end cover. Also I bought my kits thru a JEGS they had the best price.
Thanks for all the info I really appreciate it Steve |
4 Attachment(s)
Yes I have already installed the front system with the sway bar also. Thanks for the complement. I have just been taking my time on it and enjoying the process. This time I am doing the thing to enjoy it when I retire. Here are a few pictures of the front. It was not to bad to do, only the 4" hole in the upper mount.
4 Attachment(s)
Here is some better pictures. The first one is the 4" hole I was talking about.
I'm thinking about this same setup. Hope someone will chime in with how it rides and if it's worth the cost. The adjustability is the part that stands out to me.
2 Attachment(s)
3 Attachment(s)
Hey that is one beauty, I know what you mean about the price. I had to do a lot of hard thinking and decided that I was not going to spend a bunch of money on a new truck. The first one was before and the second one as it sits now. Maybe someone can turn the pictures.
I’m interested in buying the same rear coil over kit that you are using but I have a c notch kit that’s been on for a while and I wondering if you have a picture of the drivers side coil over mount so I can get a idea if the 2 will fit side by side?
2 Attachment(s)
Pics turned
3 Attachment(s)
geunther, Thanks for turning the pictures.
Speedracer39 Here is the pictures, hope they help. |
Posted via Mobile Device |
No Problem glad they helped.
I can send you some pictures if needed too. |
69GMC2004,
Have you ran your exhaust over the rear end yet? If you have can you please post some pictures ? Thanks, Wally |
Wally,
not trying to hijack a thread . but i am interested on where you got your steering shaft and joints from?? Mike |
bigmac73,
Here is the list and part numbers. I got them thru JEGS. UPPER Steel Double D U-Joint 1" DD X 13/16" - 36 Spline 153-015240 LOWER Steel Double D U-Joint 3/4" - 36 Spline X 3/4" DD 153-013449 Telescoping Double D Steering Shaft 3/4" X DD X 1" DD X 26" Long 555-607102 Wally |
