Winch behind front bumper
3 Attachment(s)
I liked the idea of mounting a winch inside the frame behind the front bumper as I have seen some other people do to their trucks. My truck is a '72 K10, and I bought a Smittybilt X20 10000lb winch.
My first couple cardboard prototypes were poor designs that mounted to the bottom of the frame rail. My third prototype (which I ended up building) was the simplest design and mounts to the top of the frame rail. This allowed the winch to hang upside down and be mounted as high up as possible. It also allows the fairlead to come out of the middle of the bumper instead of the bottom. I just had to clock the clutch housing so that the handle was pointing forward instead of down. Attachment 2031023 Attachment 2031024 Attachment 2031025 |
Re: Winch behind front bumper
3 Attachment(s)
Since I'm a graphic designer, I used Adobe Illustrator to design the pieces of the bracket. The bracket is made of two parts because it would be too long to install inside the frame otherwise. I was able to see on the computer that it was going to fit. A friend cut the parts out on a laser at his work, and the shop that did my front axle work welded the bracket for me.
Attachment 2031034 Attachment 2031035 Attachment 2031036 |
3 Attachment(s)
I had to move the radiator out of the way to drill two of the holes down through the core support and the top of the frame. I attached one bolt, then used a floor jack and c-clamp to hold the bracket in place to drill the other mounting holes through the frame and bracket.
Attachment 2031037 Attachment 2031038 Attachment 2031039 |
3 Attachment(s)
I sandblasted it and painted it with satin black paint + primer.
Attachment 2031040 Attachment 2031041 Attachment 2031042 |
4 Attachment(s)
This morning I installed and wired the winch. It was way too heavy for me to hold and put the bolts in so I got creative with a couple floor jacks. I mounted the control box where it is easy to get to on the grill center support. The controller is wired or wireless, which is a nice feature.
Attachment 2031043 Attachment 2031044 Attachment 2031045 Attachment 2031046 |
2 Attachment(s)
The winch has a synthetic rope instead of a cable, so it doesn't need big roller fairleads. I plan to get some plate bumpers made with a fairlead hole instead of cutting the flimsy reproduction bumper that is on the truck now. Total cost for material, cutting, welding, bolts, and paint was about $175.
Attachment 2031047 Attachment 2031048 |
That’s a nice setup! Looks really clean. Any plans to sell the winch mounts in the future? I bet there’s a few around who might be interested. You’d have to pony up on your paid membership but might be a good side hustle.
Very nice!
Looks very clean. Nice job!
Thanks guys. I don't want to sell it. If anyone wants the part drawing just send me a PM.
3 Attachment(s)
I found a $15 bumper in town, so why wouldn't I cut a hole in it and put it on this truck?
This also gave me a chance to get a good photo of the mounting bracket. Attachment 2033078 Attachment 2033079 Attachment 2033080 |
Looks great.
3 Attachment(s)
I used some junk sockets to space the license plate away from the fairlead. There are wing nuts on the back so it is easy to flip out of the way. The winch is really hidden now.
Attachment 2033337 Attachment 2033338 Attachment 2033339 |
Nice, I put a flip up on mine too. Perfectly legal to keep the law dogs away.
I like that, a lot. Well done.
I agree, nice job.
I like it, can I buy some drawings form you? do you run tow hooks, just curious if they still mount up. great work and thanks for sharing
we dont use no stinking front plate in pa. |
Fantastic! Strong work right there.....
3 Attachment(s)
I added some shackle recovery points where the factory tow hooks bolt on. No interference with the winch bracket.
I'm still thinking about how to make a skid plate to protect the winch, but until then I slapped a cheap waterproof winch cover on it. Attachment 2079909 Attachment 2079910 Attachment 2079905 |
Shackle mounts look good. Great idea
I really like the clean concept an simple approach.
My son an I have been looking at different Ideas as far as mounting a winch He just bought an 86k20 as his first rig, and I am teaching him as we go. He just turned 17 an really enjoys wrenching on his truck. Memo |
Very Nice !
Look into a Factor 55 Flatlink, pulls tight against the fairlead so none of your rope is exposed, and uses the shackles you have instead of a hook
https://factor55.com/product/flatlink/ |
Impressive work on your setup. The winch looks really sturdy. I might consider installing the same winch soon. I've been using Smittybilt products, but mostly as an accessory like nerf bars and cargo rack.
