Cab Mount Brackets
Does anyone make the cab mount brackets? I'm starting to design a frame for my 56 and am only finding the cab mount kit and not the brackets themselves. Worse case I can cut the ones off my existing OEM frame but would rather start with some new ones.
Thanks! |
Re: Cab Mount Brackets
Sorry, I'm not familiar with TF cab mount brackets, but for my AD I just fabricated some out of 2x4 steel turned on end:
I just gave away a set or I would get some dimensions for you. like miracle says, just fab a set from some rectangular tubing and carry on. easy peasy. check a few frame sites and see what they use......rect tubing. welded om or flanged and bolted on.
frame dimensions and lots of other pertinent info is in here. good to download a copy https://www.trifive.com/d1/55-59Assy.pdf |
MPC, did you do the welding there? Those are really nice!!!
Page 33 of Art Morrison’s catalog https://cms.artmorrison.com/assets/8...64d9f?download
Thanks everyone! This is very helpful. Will probably just fab some up.
Posted via Mobile Device |
