Ok need oil lines
MY 1992 5.7 V8 i need new oil cooler lines
what ones do i need, i herd u need to l know about rear diff gearing first? i checked my vin id says transmission short 4A/5M transmission long 4-speed automatic what do i need to get here? autozone or oreilly |
Re: Ok need oil lines
Does your glove box not have the RPO sticker?
yes i forgot about that , has G80 positraction limited slip,
cant quite make out the other letters here for ratios. |
GU6 Axle Rear 3.42
used a magnifier glass lol
just ordered them woohoo.
I don't know if your 92 is the same as my 96 K1500, but I recently changed the radiator in my truck with a 5.7 vortec, and changed the oil cooler hoses. I got mine from NAPA. They had a NAPA Gold label and I peeled it off and there was a Dorman label under the NAPA label. My longer hose was $31.99 and the shorter one was $21.99 for comparison. I would change the adapter that the hoses slide into while you are doing the job.
I deleted my oil cooler. Even the new lines leaked at the crappy push connectors.
