CA 67-72 Tow Hitch, Camper Mirrors, Eaton HO72 & More
5 Attachment(s)
Used 67-72 C10 / C20 Tow Hitch. Draw Tight brand, Class IV
Max Gross: 10,000(Weight Dist.) 6000 (Weight Carring Ball Mount) Includes Hardware & Round Plug $65. Local pick up only. $65 SOLD Eaton Axle HO52/HO72 4.10:1 ring & pinion gears. Excellent condition. This includes the ring & pinion along with whatever bits in pieces I can fit in a USPS large flat rate box. Shipped anywhere in the U.S. $400 SOLD 67-72 Camper mirrors, there is a small dent in the passenger side. $20. Contact me for shipping quote. SOLD 67-72 C10/C20 Leaf Spring Axle perch & U bolts for 2.25" Leafs. $20, Contact for shipping quote. |
Re: CA 67-72 Tow Hitch, Camper Mirrors, Eaton HO72 & More
Pm sent
I will take the camper mirrors. Shipping cost to 99645.
2 Attachment(s)
907burb, jfj537 inquired about the mirrors first, if he doesn’t buy them I will let you know.
jfj537, I noticed some plier marks on one of the mirror stems when packaging the up. They are on the same stem, other one is fine. Photo attached. |
Mirrors sold.
2 Attachment(s)
I disassembled the axle now Eaton HO52/72 ring and pinion available. Excellent condition gears look very clean.
Would you take $300 for the Eaton gears
Payment sent
I’d love to have the hitch assembly any part numbers so I may check if it will work on a 72 blazer. Also where in simi I’m off topanga on 118
Hi Tmend, I will look for a part number when I get home from work. It bolts to the bottom of the frame rails. If your rear frame rails are 33.95" wide (overall) then it may work. I will PM you my phone number. My house is off Erringer Road if you want to come check it out.
