Which AC compressor for r134 AC?
I bought all the factory stuff I need to convert my heater truck to AC. I was going to go with vintage air but wanted to be able to pull in fresh air because the south is very humid.
Anyway. I think I have figured out most of the stuff I need to do a r134 conversion when I install everything. The only thing I am still up in the air about is the compressor. I was looking at an AC delco A6 compressor from rock auto. Would that work without pulling too much HP away from my engine? Is the sanden a better option? Any more options? I want to be able to stay the coolest and use as little HP as possible. I’m pulling 16.5 mpg at 70 with my 350/sm465 307 rear right now and would I like to not take it down too much by adding AC. I also will usually drive the truck at 1300-1500 rpm in town. It just putts. I drive it like an old man (no offense to any old men). Would the A6 even work well at idle or low rpms? Thank you. |
Re: Which AC compressor for r134 AC?
I drive like you do. I used a 4seasons aluminum A6 which works fine. Since I bought that thing I've heard some have had them fail. If I were to do it again I'd get a rebuilt GM/Delco/Harrison/Frigidaire. I used this condenser with the Vintage Air mount. I don't notice the HP loss and it gets plenty cold.
I'd use the stock type A-6 compressor if the conversion uses a POA valve adjusted for 134. If you are going to a switch to cycle the compressor, use the R-4 compressor, because the A-6s don't suffer cycling gladly and fail fairly quickly, based on what I've seen over the years, here. You probably already know, but the oil for a 134 system is different.
I run the A6. Next time it fails...I'm replacing it with a Sanden. -klb |
Yep, the clutches don't have the surface area to by cycled on and off.
I use an A10, aluminum replacement for the A6. Factory AC in my 68. No leaks, no belt squealing, been working great for about 4 years now. I used R12 as original. I will never use an A6 again.
Who made your compressor and the part number? When I bought mine a few years ago I understood I was buying an A10 but the manufacturer's description says it's an A6. Mine is a 4 Seasons 58098.
I don’t recall the manufacturer. I would imagine they all come from the same place, with each vendor putting their name on it. I bought an entire kit from autozone that included the compressor, drier/receiver, expansion valve, and a quart of mineral oil. They called it an A6 replacement but it’s an A10.
I have been the A6 aluminum replacement (four seasons) for years. Works fine. But, it came out with the engine to replaced with a LM7 LS engine...switching to R134a and using the Denso LS compressor. Going to try and sell the engine/700R4 as a package including the compressor.
So maybe mine is actually an A10. I'm using ester oil in case I didn't like the R134 result and opted to switch back to R12. With the POA properly adjusted R134 works just as well as R12. I love POA systems!
I never had any luck with r134 in a factory AC system conversion, even adjusting the poa and other factors. If it works for you, great. I’m happy with r12. I have stockpiled both and use 134 in all of my newer cars that call for it.
Thanks |
ackits.com was where I bought mine but that was about 20 years ago. It lasted a little over 10 years when I assume the clutch failed as it still turns by hand.
` Quote:
Having a system that lets you open & close the fresh air intake is the best option but max cooling & dehumidification is accomplished when the air is recycled. |
