Ls3 tr6060 swap
Hi guys I am doing a total rebuild on my 71 and am almost done with the chassis.I’m looking to put in an ls3 and tr6060 but I have a few questions.do I need to get a high hump floor? Also do I need to do anything as far as relocating the shifter or does it line up pretty well as is? I don’t have any seats yet but I’m planning on doing buckets. Thanks for any help!
Re: Ls3 tr6060 swap
Not sure about your hump...but I'm betting you'll need to relocate the shifter..
I'm gonna use silversports on mine when I get to that build |
Re: Ls3 tr6060 swap
If your LS3 and trans came out a Camaro as I understand the shifter is some sort of a remote mount not mounted to the trans case like a T56. There kits available to change that. When I did the T56 Magnum in my 68 I added a high hump to reduce the engine/trans angle.
