What do stock master cylinder brake lines look like
I need to bend new 1960 chevy truck master cylinder brake lines for my truck but can't find any pictures of original.
Re: What do stock master cylinder brake lines look like
Not sure if all our years are the same but here is a pic from the Lambrect thread
http://67-72chevytrucks.com/vboard/a...1&d=1383705652 |
1962 GMC 4x4
Let me know if you need more angles or better lighting. |
I can snap a few pictures tomorrow for you. My 4x4s are GMC with the spicer axles but the only difference should be how they connect to the backing plate. This picture shows a little. I can get a dfew more. |
Not sure what you mean by snubbers?
2 Attachment(s)
I have several trucks like this so I believe this is factory method. |
LMC Truck shows they might be available # 30-1828 GM Parts book search shows # 3700034. Did a quick search and it looks correct. |
60 4x4 hydraulic hoses
Looks like I need one for my clutch, does anyone know where I can buy one?
Re: 60 4x4 hydraulic hoses
They're not "factory looking" because they come in braided hose, but they work. |
Don't mind helping. Been own the path on some of it.
If your original is intact you can send for them to copy if for some reason they don't have the application. I had to make minor adjustments to mine when it came. Keep them in mind for parking brake cables also. I've had them make a bunch. Same drill. Send em yours, and they'll copy and send back. Had good luck with them. |
3 Attachment(s)
This is my balance bar but does the main cable attach to a bracket somewhere between the handle and the balance bar?
2 Attachment(s)
does anyone know what these 2 brackets are for? |
Main cable bolts to the t-case cross member with a simple clamp. It runs on the drives side. Will try to get you a photo. |
The trianglar shaped one with the slot in the end i think is the original. Some trucks had these and ran a metal band arount the muffler body. My `60 apache has one similar although it is 2x4 variety. Hard to tell from the pictures but any mysterious heavy duty brackets could be remnants of a pto driven accessory. By suburban had a few that used to support a pto driveshaft for a pto driven winch. They are commonly on divers side since that is the pto side of the SM420 which i asume is what your truck has. |
