primer question
I just finished applying 1:1 epoxy primer on the hood and the pass. side fender and door. I would like to spray slick sand next. Is there a window of time that I can put down the slick sand over the epoxy without sanding the epoxy or does the epoxy have to fully cure before continuing?
Re: primer question
look on the tech sheet for your epoxy primer...it should have the recoat window on there..it differs from manufacture to manufacture
