Patch panel
I pulled up the carpet on the '69 C20 and I found some rust that will need to be cut out and patched up. Seems to be a common location right below the high-low dimmer switch. What size gauge metal would you recommend for this location ?
Thanks ! |
Re: Patch panel
I don't know a lot about sheet metal but that spot isn't too big so I would say 18 or 20 ga. should do it. LockDoc |
Re: Patch panel
3 Attachment(s)
See your in Wappingers falls I have a house in the Riverview area off of Channingville rd . |
Re: Patch panel
Re: Patch panel
