Door gap & shim help
3 Attachment(s)
As I've posted before my old girl went without the top and both doors for a long, long time. So far, I've gotten really lucky with the top and the drivers door. However, I think I could do a little fine-tuning on the passenger door..., along the rear of the door the gap is tighter at the top and opens the lower you go. The front of the door is pretty close. From reading other posts and looking at the diagram from the assembly manual, shimming at body mount #2 (b-pillar) affects the rear door gap correct? As a rule of thumb, does adding shims open the gap? Presently there are no shims at mount #2, and there are two shims at mount #1 (a-pillar through floor pan). I should point out that I have already replaced all the body mounts before I started. What do you think? Here are some photos, thanks so much!
Re: Door gap & shim help
If you add shims at the #2 B pillar, you will increase the gap at the top of the door. You will need to add quite a bit of shim before you start seeing any movement. You may have to loosen the front mount bolts to be able to force the shims in .
I just want to line it up as best as I can before I start the rust repair. This will be a daily driver, and if I can't get the gaps any better I'd be happy with where it is. Just curious what others think, if the gapping is within norm. I'll probably add some shims at #2 and see what happens. Is it normal to need shims on one side but not on the other? The more I fool around with this thing, the more I'm convinced there weren't two alike off the assembly line.
3 Attachment(s)
A few things to consider...
How are your door hinges - is there any slop? Do they sag when you open/close the doors at all? I just went through door to bedside gaps in the past 6 months. My thought process as I line up the doors/bedsides:
Yes - shims can vary between trucks and from side to side - I always replace the number of shims at each location when swapping them the mounts and bolts. I spent many hours working (and then reworking) the gaps and I'm still not as happy as I'd like to be with them. Here are a few pix from when things were coming together with all new sheet metal on the 71 I am rebuilding... |
Those slots though. Nice
