air flow on intake filer cause rough idle...?
2 Attachment(s)
I noticed that when my cooling fans come on at idle, my motor would start running rough. i figured out that it was air from the fan blowing onto the intake filter that was the issue. why I don't understand.
i moved the intake tube out of the line of the fan blast and all is fine, but id like to understand what is going on. I know others have their filters in the fan blast and don't have this issue. I found I did have some vacuum hoses run incorrectly at first but have them all sorted out now, and the issue is still there. i made a video showing how a small fan on the intake causes a rough idle. perhaps that is normal? https://youtu.be/9Ig1KhCTtLI |
Re: air flow on intake filer cause rough idle...?
The additional air from the fan can "fool" the mass air flow sensor giving the ECM a false reading.
double post
is the ECU tuned for the different mass air sensor if not stock? that tube size is probably definatly not stock diameter.
when I bought the airraid universal maf card adapter, it was a little larger than OE. it would make it run like crap till the tables were tuned. this is a L83 motor which may be different than LS tuning? look at the scanner and see what its showing.. Clint |
Speartech did the harness, tuning, and it is their intake tube and sensor. I've spoken with them about it they are stumped as well. perhaps a faulty sensor? it will send a code for the sensor when I put a lot of air in with a bigger fan.
in its current position, everything runs fine. |
absolutely unrelated, but thought I would share, I watched a youtube video while back on customizing something... wound up on a hose clamp mod / trick / hack or something or another.... dang it was stupid awesome.
https://imageshack.com/i/pncRFGM6j (on the intake tube coupler) harbor freight roll of heat shrink tube over the hose clamp, then shrunk down with the heat gun... clint |
Very cool on the hose clamp thing.
