Can I cut these off the block?
2 Attachment(s)
Went to throw a 2006 Tahoe 5.3 into the 1967 k10 and these little nubs are in the way,can I cut them off? Mainly the one with the webbing cast into is concerning me.
Re: Can I cut these off the block?
I would say you can as long as you don't get too carried away. But wonder why you would need to? I have never had an issue with them or even heard of anybody that has had this problem.
are these slider mounts your using?
How close is the rear of the valve covers to the firewall?
It looks like the engine is way too far forward. |
are the k10 mounts different? with my dingo sliders that casting is almost 2 inches away from my engine mount
Truck was originally a v6 |
so are those the v6 mounts too?
if i remember right those mounts either need to be moved to the v8 holes or you need v8 mounts. someone else can chime in to make sure but it was something along the lines of that. |
V6?
May need v8 mounts,, the v6 mounts may be what's causing the issue |
