Chrome going back on
Chevy is in the paint shop, and adding all new chrome.
With new doors, box sides etc. no chrome mounting holes. My body guy is ultra fussy on where everything goes. I do know where the emblems go. Anyone can point us in the right direction greatly appreciated! :chevy: |
Re: Chrome going back on
What year model and appearance package are you planning to have installed?
Are you looking for factory trim instructions...like this.....measurements are in 10/th's of an inch, makes it a real head scratcher.
Upper and lower complete both sides. Tailgate too. Have a peek at my photo on the left, its original. |
The issue with the factory location diagrams is the reference lines are not defined.
Check out the Horizontal reference line (15) what is the location? The chrome side molding or a sheet metal crease? The front to back holes are located by using (line 115) Again no reference. Ends up you know the distance between the holes it about it. You are better off to locate the top of the side molding with the tail light and use that. Be sure your bed is lined up with the cab and run a tape line all the way front to back. I had the same issue with the tail light bezel. I got it but it took awhile. I taped around the perimeter of the bezel and then used a felt pen to mark out the position of the bezel. Then marked the holes on the tape. Touch up the drilled holes with some paint before installing the clips. Try the clips in the holes before mounting them on the trim to be sure they fit in the holes, quality control it terrible and varies by manufacture. Sometimes greasing the clips before installing is required. Cheers. |
Gonna test fit everything before paint. |
