1972 k30
5 Attachment(s)
Ok time has come to document this build and progress on the 1972 k30 build. In the works is
Power train -Stroked BBC (1969 427 2 bolt car) -4l80e (2003 gmc) -Twin stick NP205 (1991 1 ton) -Holley sniper (will also control the trans) -HD 4x4 engine crossmember built by CFM industries (We used my chassis for the proto type for a product that was desperately needed in the market) Chassis -1971 Chevy K20 -52" Alcan 4" lift springs -Diy4x4 B52's up front and their shackle flip in the rear (should be around a 8 inch lift) -1.5 dom Crossover steering and tie rod with barnes 4x4 weld in inserts Diffs -14 bolt w/ 4:56 & Grizzly locker built by Great Lake Offroad with their disc brake kit and hd cover. (I need to run the numbers on this because it is a direct bolt in for our trucks) -Dana 60 w/ a spartan locker, yukon 4:56's, hd lock outs, 35 spline stub shafts and GLO hd cover. I acquired the chassis from a local pick and pull (Feb 19')but didn't decide to build the truck until my dad and I made a 3 hour trip out to plains to buy a cab off a Facebook post (May 20') Well enough off blah blah here are some pics from the adventures of my old man and I playing with trucks |
Re: 1972 k30
5 Attachment(s)
Worn out, greasy, rusty, dirty parts
Re: 1972 k30
5 Attachment(s)
Diffs
Re: 1972 k30
5 Attachment(s)
Fighting king pins.... After stripping the 7/8 hex, then running out of gas with the torch and uga dug power on the breaker bar I used a you tube method of welding a piece of steel to the king pin. It didn't say no when I hit it with the 10lbs sledge (my purse):lol: Had to borrow a friend's BA torque wrench to get the new king pins to 600 ft lbs!!! To say the least I was a little intimateded but it went smooth with the 5ft handle.
Re: 1972 k30
5 Attachment(s)
Did a road trip with my dad to Alcan Springs in Grand Junction to grab some buddies and my springs. They gave us the nickel tour of their spring making process and wow these guys are a top notch small biz. B52 52 inch spring conversion and shackle flip and dropping the frame off to get blasted.
Re: 1972 k30
5 Attachment(s)
NP205 came put of a 1991 1 ton but I didn't get the golden adaptor. Cool thing is that it has the gm vss in the output for the 4L80e. Was a pretty simple rebuild for playing with my first one. Had to get new shift forks and shift collars because they had some hefty wear. A friend of mine milled down the shift rail detents for the twin sticks.
Re: 1972 k30
5 Attachment(s)
NP205 twin stick shift rail with detents milled out next to a buggered up stock rail. 4L80E was built by TnT automotive and random pic of the chassis
Re: 1972 k30
3 Attachment(s)
Pics
Re: 1972 k30
5 Attachment(s)
The cab was built summer of 2020 and I did most of the work with supervision because my dad had his shoulder replaced that April. He showed me more tips and tricks that i can add to the hat. Panel bond for the win on the rockers
Re: 1972 k30
5 Attachment(s)
I gotz the bluessss :cool:
Re: 1972 k30
5 Attachment(s)
Glass, door and Q-pads
Re: 1972 k30
5 Attachment(s)
Bed
Re: 1972 k30
5 Attachment(s)
More bed pics
Re: 1972 k30
5 Attachment(s)
Bed is on the frame and looking goofy with them little tires. Had some 72 steel DG4 mirrors chrome plated thanks to a good friend and some other parts zinc plated at Denver Metal Finishing.
Re: 1972 k30
5 Attachment(s)
CFM Industries 4x4 engine crossmember.
In the begining i was going to put an LS 6.0 in the truck and after searching I wasnt impressed with the products avaible in the market. I then contacted CFM about if they made a crossmember for 67-72s because they had a LS one for square body's. They said they didn't but would like to scan a chassis with their 3D scanner and asked if I could bring it there. Turns out they are only a couple miles from my shop and ended up coming over with their super high tech 3D scanner to scan the frame. After me changing to a BBC a few renderings Darren engineered this one and wow.... No drilling, no modifications to the brake lines, 0-2.5" forward adjustment from stock, removable cross section for oil pan access and here is the kicker small block, BBC or LS adaptable with clearance to keep the AC compressor in the factory location. Pretty cool to be part of this product because it was a void needed for us 67-72 guys |
Re: 1972 k30
Looks like excellent work Curt. Following.
Re: 1972 k30
Just got the big blocks back from the machine shop. The 427 and a 402 for a later project. Just ordered the parts for the 402 today and started looking at heads and the stroker kit for the 4x4. Figured I'll practice on the 402 for now. More fun coming up soon. |
Re: 1972 k30
Nice work Curt, that’s gonna be a really special truck when you are done. I still have the one me and my old man built way back when I was in high school. Can’t wait to see it continue to come together. That crossover setup on the 60 looks good. If I ever decide to take mine that high I’m going to do something similar with my 60. I keep swearing that 4” is all I need but I do like them up in the air. That crossmember looks awesome, I’ll keep it in mind when I get to my 6.0 swap.
Re: 1972 k30
Very nice work on this K30! Everything looks beautiful. I really like that engine cross member. There definitely weren't many options for these trucks. Finding original ones that are nice is tough and I hate those stupid flat mounts mainly because they suck to put the bolts in. :lol:
What did you use to paint your frame and suspension? Your trans and tcase looks very nice as well. I've got a 72 K20 Cheyenne Super I'm working on now and I almost went with that blue and white but I might paint it back to it's original colors. I'm not sure. I've always liked that blue and white but never had one. |
Re: 1972 k30
Awesome so far. How are you putting the 205 on the 80e?
Also i see your paypal in your sig. Does that mean you want donations?:lol: |
Re: 1972 k30
Re: 1972 k30
LMAO at the donations. Maybe you're on to something? :lol:
Re: 1972 k30
Cool to see this one finally got a build thread going. I'm going to have to reach out to CFM on that cross member an 8.1 that I've got laying around just might fit in that.
Re: 1972 k30
5 Attachment(s)
Haven't worked on the truck much because work has been eating up the fun time but did get to tinker with some interior stuff last Saturday and hang out with my ol man. Installed some black carpet material in place of the jute pad on the firewall, radio and heater boxes. Mocked in the modified under dash harness that hopefully is set up good for the Holley sniper that ships June 30:smoke: The 402 for another truck is finished and now time have to shift gears and get going on the big block for this truck. |
Re: 1972 k30
I’m really digging this build thread.
