10 gauge wire through firewall - connector?
I am running an additional 10 ga. power wire from the rad support junction to under the dash to power a couple of relays. I have a few available holes in firewall and grommets to fit. I just hate putting a continuous wire through the firewall. Can anyone suggest a bulkhead connector for a single 10 ga wire? Double is ok too, I am reluctant to just hard wire as I know it will all come apart "soon" when paint work begins. Thanks for any suggestions. I've used the extra plug pins already.
Re: 10 gauge wire through firewall - connector?
Use Packard 56 terminals and add them to an empty slot in your bulkhead connector.
I've already used the empty slot in the main bulkhead connector and the empty one in the engine harness plug. I'm hoping to find a small round connector to take advantage of one of the other existing holes in the firewall - ~5/8"
