Powersteering conversion issue
So i have a 1971 c10 2wd. I’m trying to convert it from manual steering to power steering. I’ve read the swap info section a few times and searched this forum. I have steering gear 7802644 and found I needed a 6131 pitman arm. The issue is that the inner tie rod hits the crossmember before I can get the pitman arm on. It does have wilwood drop spindles on it.
Thanks for any further info. Charley. |
Re: Powersteering conversion issue
I never even thought of that. I never installed the steering. The truck was purchased as a roller and was freshly assembled. Thanks.
Pics for verification
