C30 Sway Bar w/ Flip Kit
Good afternoon friends and family! Well I finally got my Dually on the road and really want to get my sway bar put back on after my flip kit before it goes off to the alignment shop.
Has anyone put the rear sway bar back on after doing the flip kit? If so any pictures and what did you have to do if anything? My rear brackets are off getting blasted before powder coat and then it's time to tackle the project. |
Re: C30 Sway Bar w/ Flip Kit
3 Attachment(s)
I didn't get very good shots of this but this was with the stock end links. I changed them out for much shorter ones before driving it too far and the bar is almost parallel to the bracket now and have never had an issue. The picture of the truck is with no air in the bags and that's the position I used to get the end link measurement. I would get some better pictures but the truck is in the body shop.
Thanks again for the pictures. |
I considered it for my set-up but figured I would see how things were as-is w/o a bar. The outboard bags & 4-bar/Panhard bar combo do a good job of keeping things in check so I never re-installed it. |
