New to me 66 c10 front disk upgrade question
Finally got myself a 66 c10 and one of the first things I'd like to do is upgrade the manual brakes to power brakes and at the same time a front disk conversion and probably lower it 2/3 while I'm at it. I noticed both lmc and brothers have a 17" wheel diameter requirement on their kits. Cj pony parts grand slam kit doesn't mention this or any wheel size requirement but I sent an email to them asking if there is. I wasn't planning on new wheels and tires at the same time because one the 16" wheels I have are in really good condition as are the tires and two that's a husky chunk of change I'm not super keen on spending right now. Interested what other options you guys have used
Re: New to me 66 c10 front disk upgrade question
I used a CPP power dual master/disk front kit with 15” wheels.
Cj pony has the worst customer service out there.
Try calling them and you will find out exactly what I mean. I highly doubt you will ever get an email answered. IMHO; Try anyone else but them. |
I purchased a kit from Performance Online for my truck almost 7 years ago. I haven't had any issues with the kit since then. I am running 15x8 wheels with no clearance issues on my discs. Basically, I have the same 1.25" rotor that is used on the 71-72 and squarebody trucks (with 1.25" rotor, not 1" as many later squares were.)
I have stock height spindles, but in your case, a drop spindle would be best for what you want to do. I have heard in the past of some 15" wheels not fitting with 3" drop spindles. Since you already have 16" wheels you will probably be ok with running a 2.5" drop spindle, depending on your back spacing. |
Here is a great reference thread - http://67-72chevytrucks.com/vboard/s...ight=dash+swap
I've swapped CPP's drop spindle/disc brake kit on a few 64-66 trucks and none of them needed bigger than 15" wheels. There is a clearance issue with the inner barrel of the factory drum brake wheels- the inner barrel is slanted at a 45* angle and that area will hit the caliper. You can used a bolt on wheel spacer to gain clearance, or use newer 4 nub truck steel wheels that have a stepped inner barrel made for clearing calipers.
Neither of the CPP kits I used needed a booster, they stopped really well with minimal pedal pressure with a 1" bore manual master cylinder. A booster adds complication and has worse pedal feel/feedback, and when you add a booster you have to modify the pedal linkage to take away pedal leverage from the booster/master.... that kind of defeats the purpose of adding a booster. A lot of booster/master cylinder combos are 1.25" bore, again reducing the amount of "leverage" your foot has on the brakes so that the pedal isn't too easy/soft. Try it without a booster first. Make sure to use a master cylinder that is made for discs, the stock master cylinder has a build in residual valve that will cause discs to drag. |
When swapping to discs, one needs disc brake spec wheels. When swapping to discs & drop spindles, back-spacing of a disc brake spec wheel needs to be kept in check for 15" wheels to work but they will work. |
If the CPP kit with manual brakes had any easier pedal effort the pedal would be too sensitive and it would be easy to brake too much. I'm guessing they use a really aggressive pad compound to get it to stop with minimal pedal pressure but it works great with a 1" manual MC.
Changing brake pad compound can make a huge difference in pedal effort; my car with boosted brakes was really hard to stop and the brakes felt inadequate when I first bought it. I let my dad drive it and he agreed that something was wrong with the brakes. Pedal effort was excessive in normal driving, and it took a ton of pedal pressure to get it to stop really quickly. I swapped to Centric PQ Pro semi-metallic pads, bedded the pads in, and the pedal effort is now normal. I could see a truck with ceramic pads needing a booster, they have a very low coefficient of friction and would need more line/pedal pressure to stop the truck. |
