3 wire 10si alternator conversion
hello everyone,im upgrading from the external regulated alternator, to a 10si internal regulated 63 amp alternator. I have done a search on the forum, and see that the conversion is pretty easy and strait forward to do. my original wiring harness is from a 69 c10, and is in excellent condition, never been cut or altered, except for the fusible link at the battery, which I will be replacing with a new one.The only add on to the truck is a HEI distributor in place of the stock points distributor, and I am going to eliminate the stock resistor wire, and run a new wire for that. with that being the only modification to the system, has anyone ever had a problem using the original 12 gauge wiring and charge circuit. I had thought about upgrading the charge circuit to 10 gauge, but hate to cut into a perfect original harness, if not needed. I already have the plug and play conversion adaptor kit for the harness connections at the regulator and alternator. thanks!
Re: 3 wire 10si alternator conversion
I did the 3 wire conversion on a 71 GMC I have. I used the plug in harness adapter from American Autowire. No cutting or splicing and the original charging wire has been more than sufficient.
No need to cut and replace the factory charging wire . I added a 125 Amp alternator to my chevelle I just added another wire and zip tied it to the harness. So now I have 2 wires running from the alt to the battery . Never had a problem
