1978 Chevy Scottsdale K20 Camper Special
5 Attachment(s)
1978 Chevy K20 Camper Special
350/TH400/NP203 Odometer shows 19,xxx but true mileage unknown. Dana 44 front/Full float 14 bolt rear New wheels and tires Runs and shifts well Just did a tuneup (plugs, wires, intake gasket, set timing, replaced fuel pump) Front brakes rebuilt-rotors, pads, calipers, hoses, wheel bearings New front driveshaft New interior (dash pad, gauge bezel, bluetooth radio, front & rear speakers, flooring, seat foam & cover, door panels, heater core, headlight switch, turn signal switch, instrument cluster circuit board) New window regulators, mirrors, grille, all new bulbs and lenses Very little body rust. Some bubbling at wheel openings and some rust under battery tray but is a solid truck. This truck is geared pretty low - probably 4.10 in the rear and 55 MPH is about the max. Fuel gauge does not work - probably needs new sending units. Could also use carb adjustment or rebuild. Asking $7,500. Located in Grand Junction, CO. Can provide more photos upon request. Attachment 2265480 Attachment 2265481 Attachment 2265482 Attachment 2265483 Attachment 2265484 |
Re: 1978 Chevy Scottsdale K20 Camper Special
Good afternoon,
Is this truck still available? Greg in Missouri |
