Dana 44 Closed Knuckle Axle Shaft U-Joint Part Number
Morning all!
Can anyone tell me the U-Joint part number for a closed knuckle D44 axle shaft? I am rebuilding mine and want to replace the U-Joints, but I am not sure what part number to order. Thanks, Clay |
Re: Dana 44 Closed Knuckle Axle Shaft U-Joint Part Number
Should be Spicer 5-260X https://www.northerndrivetrain.com/p...PI-5-260X.html
Thank you much! I will get them ordered. Clay |
Ok, so I ordered the new ujoints for the axle shafts. The original ujoints did not have the seal on them as it is all lubricated from the special sauce that lives in the knuckle cavity. The new ujoints have the seals on them. Do I have to remove the seals, or just let the permalube idea take care of itself?
Here's my take, I'd leave them on. They're more than just dust caps. Think of it this way. I used to have an old paint brush spinner. I would stick the brush handle in it and stick in a empty buck and it would spinn the excess paint off the bush bristles. If you stuck a joint without the seal, let's say a driveshaft. It would be exposed to dirt sand and the likes. But.. would it spin the grease out of the joint trunnion? If it's inside, will it take on grease, or lose grease, or neither. For me, the low hanging fruit is leave the part as shipped and install it. Good luck; and have fun! :chevy: j |
j |
So sounds like you’ve decided to keep the closed knuckle for now? I’m guessing you’ll be very happy with it when you’re done, and if not you can always throw in that newer one later
As far as the seals on the U joints you would probably be fine either way, but yea I think leaving them on is the best way to go. That same joint will last many thousands of miles in the environmental hell of an open knuckle, so enclosed in a nice clean closed knuckle it will last many times longer. Just like every other mechanical system on our trucks, the only thing that will kill a part is too much horsepower or not enough clean lubrication. Don’t think that you don’t have to worry about keeping the lube topped up in the knuckle though. Remember that’s the only thing lubricating the upper and lower bearings. I also love the Corn Head grease. Never could keep 90W in those things. Tom |
Yeah, the more that I pondered on it, the more that I wanted to keep the truck original. I had the drums checked out and they were ok to turn. Also the price to get new drum brakes was considerably less than a full disc brake conversion. Lastly, using the original axle I don't have the mess with regearing anything. So, for now I am going to stay with the original axle. If I decide to change later on down the road, I can alway swap in the closed knuckle. This will also allow me to to spend money on other parts of the restoration that are more important at the moment. Clay |
Well now you guys have me (over?) thinking about this whole seal or no seal thing. While I still stand by my original thought that it probably doesn’t matter either way, Jeff brought up a really interesting theory. It all made sense until I realized that the knuckle fill hole is about at the center of the axle shaft, so the analogy would be more like constantly dipping the paint brush into a can of paint, not spinning it dry. This would force grease in with every rotation.
While I don’t have access to part numbers to prove it, I’m thinking that the same u joint is used for both open and closed knuckles and you simply leave the seal on for open (to retain grease) and remove it for closed (to replenish the grease). It makes sense to me, but if not the case, please let me know as I’m here to learn, not preach. On another subject, I hope you know to replace the oil seals just outboard of the pumpkin. It’s a real PITA but needs to be done while you’re in there, as they are probably original and will cause no end of problems if they start leaking. Keep up the great work Tom |
Yeah, I am replacing the inner axle seals. I pulled the carrier out the other day and noticed that the seals were crumbling apart. The nice thing about the older carrier setups is that the shims are between the carrier and the bearing and not the bearing and the housing. So reassembly will be a piece of cake. I would imagine that initial setup for preload and backlash would be a pain though. Clay |
The inner on my driver side got to the point where I couldn't ignore it anymore. So I did axle upgrades and the inner seals last summer. I used the seal install tool, made it a bit easier. I replaced all the shafts, bearings and hubs ect... while I was at it. I just did a quick sanity check with the dial indicator before I closed it up. I checked it before I dropped it out and no change. :chevy:
j |
Clay |
j |
I was actually lucky enough to find a front Dana 44 from a 73/74 that had them. They are getting harder and harder to find and if you do find a set, they are pretty spendy. I was concerned at first that they would not fit the closed knuckle axle, but the internals are all the same. I installed one to verify, and they install perfectly! I am gonna keep the originals, but I really want the Spicer's. I like the way they look and they are period correct for the K20's. I have the entire axle tore down at the moment and I hope to have it painted and begin the rebuild this weekend. I will post pictures on my build thread as soon as I get it completed. I really want to get the chassis and motor done so I can move onto the body work. I have never really done that before, and I am kinda excited about giving it a whirl.
Clay |
When I recently went through my front end I put in a TrueTrack. Was afraid it wouldn’t be a good idea, especially since I have manual steering, but has been great both on and off road. I have TrueTracks front and rear in my other Brand X truck and that’s worked out really well. Never know they are there until you don’t get stuck! Tom |
I built the front 60 with the installation of an ARB or OX in mind. If I'm happy with the 35s and 4.56s I'll probably put an OX in the front 60 and call it a day... and continute to threaten the detroit with a new home! Building it is the fun for me now days. I don't offroad much anymore, But I love a capable truck. :chevy: j |
