1968 GMC K2500 3/4 ton 4x4 Long Bed Stepper
5 Attachment(s)
This truck was rescued from a field a couple of years ago out of California. Dropped in a 292 six-cylinder motor with the proper cross member and mounts.
The truck had a bent tie rod up front that only let it turn to the right. That was replaced with a brand new tie rod and end fittings from Barnes 4x4, 1-ton version. Everything turns great now. The passenger side stepside fender and step were crushed in. Metal worked the fender to look very presentable and replaced both steps with a set from the forum. Installed new ignition with tumbler, wiring harness under the hood from American Autowire, new hoses, belts, ect when installing motor. The bed wood and metal strips are toast but purchased new Ash wood, metal strips and hardware for the bed that go with the truck. The truck has factory-stock 17" rims that are noted on the pieced-together build sheet. The truck is a good running and driving truck that could be used as is or finished up to the next level. The truck is registered in Vermont with a current plate and registration. Vermont does not issue titles for anything over 15 years old. Take the registration to any DMV and they will turn that registration into a title or leave it registered in Vermont which will cost about $70 per year. No trades, I am thinning the herd. $9400 |
Re: 1968 GMC K2500 3/4 ton 4x4 Long Bed Stepper
5 Attachment(s)
Here are a few more pictures
Very Nice!!!!
That’s pure awesomeness right there. I wouldn’t change a thing.
What does the cab supports look like?
Drew67 I sent you a PM
Great looking truck and nice work on that build sheet puzzle.
Shift pattern decal is in incredible shape. If you get time, please post a pic of the Jack Inst. decal and SPID if you have it. Going to make someone a great project, wish I was closer. |
Sent you a PM
Sale is Pending to 72 K15
Truck is SOLD and going to North Dakota for member "72 K15"
Landarts is great to deal with, now to find a shipper not so sure I trust all these brokers.
Hard to find someone better
If anybody knows of a good shipper let me know.
Are you gonna do some kind of thread so we can watch what you do with it?
Yeah I probably will, I plan on getting new rims on and tires and driving it for the summer doing small fixing things, wirring bed wood stuff like that, and eventually hopefully a nv4500 and np205 and newer Dana 44 axle
