Anybody running manual disc brakes? Pics
2 Attachment(s)
Hi there in order to do some troubleshooting on my 1971 GMC 1/2 ton CORRECTION (71 cab on a 69 chassis) that came with factory drum brakes at all four corners that I have since converted to disc in the front I need to install a non power disk brake master cylinder and I would love to see some pics of how that mounts. My drum/drum setup was power so it had the big vacuum booster can on it
please and thank you |
Re: Anybody running manual disc brakes? Pics
1971 with drum brakes in front, I didn't know there was such a thing.
I have a 1969 C10, I put on it 1971 donor front disc brakes and spindles with new 1971-72 ball joints and steel brake tubing, and 1971 donor rear drum brakes and new 5-lug conversion rear axle shafts. I did manual brakes. The master cylinder bolts directly to the firewall. https://67-72chevytrucks.com/vboard/...7&d=1673930048 http://www.67-72chevytrucks.com/vboard//showthread.php?p=9167631#post9167631 |
1971 was the first year of disc brakes in all the trucks. There were many trucks with manual disc brakes from the factory.
Yes that is what I thought, and I didn't know front drum brakes were an option for 1971. Gregski may have had the only one. Or it may be a GMC thing.
"Drum to Disc" conversions 67-70 pics and videos |
I do on my squarebody. Master from a '84 with manual brakes.
Aluminum master plastic reservoir |
yes, you can bolt directly to the firewall per djmlambert's great pic (pro looking conversion!). Also note he's got 3/16" lines on the disk circuit and 1/4" lines on the drum circuit, just like the factory 71+ disk/drum set-up. A stock 71-72 combo valve would be perfect, or you can run an aftermarket adjustable prop valve - but you are correct in that the original distribution block from a 69 is not the correct valve for your soon-to-be-modified brake system. It appears you have the correct mc in your 1st post; assuming you purchased a manual brake mc (for disk/drum), it should have the deep hole in the rear piston (as opposed to the little shallow hole that accepts the short intermediate push-rod associated with a booster. Recommend check that your mc has a deep hole piston in the bore where it accepts the brake pedal pushrod. If it doesn't, i.e. just has a shallow little depression where the push-rod goes, then you may have a power brake mc (for disk/drum).
I sold my 71 gmc 1500 a few years ago. It came with non power discs up front. Master was mounted to the firewall just like in the photo above. It took me a few attempts to locate the proper NON POWER master, finally got it at Napa by going into the old paper parts books. Guy on counter was useless.
I will check like you suggested |
2 Attachment(s)
my 72 was manual disc/drum but I converted to power.
Here is a pic as it was with stock manual MC |
Gregski, LMC used to carry manual vs power 71-72 master cylinders - here's a part # ref for you - https://67-72chevytrucks.com/vboard/...81&postcount=7
Love your L6 with power steering !
2 Attachment(s)
Now power disc/drum brakes to.... |
Some Specs BrakeBest Select Brake Master Cylinder - New - NMC11339 Warranty: Limited Lifetime Warranty Unit of Measure: Each UPC: # 848074025655 New Or Remanufactured: New Dust Boot Included: No Number Of Ports: 2 Bore Size (in): 1.130 Inch Reservoir Included: Yes Bore Size (mm): 28.58mm Reservoir Type: Integral Number Of Pistons: 1 Sensor Included: No Number Of Mounting Holes: 2 Gasket Or Seal Included: No Bleeder Kit Included: Yes Pedal Rod Included: No Brake Booster Included: No Port 1 Thread Size (Forward) (in): 1/2-20 Inch Port 1 Thread Type (Forward): Inverted Flare Port 2 Thread Size (in): 9/16-18 Inch Port 2 Thread Type: Inverted Flare Master Cylinder Body Material: Cast Iron |
I don't know for sure about the master cylinders for manual disc brakes in our trucks, but I do know that in Pontiacs that the manual disc master cylinders were a one year only option and they had a different bore diameter than the power brake master cylinders did.
Last time searched for one I had to have the counterman look the number up in a BOOK! :ack:There was no listing in the computer for a manual master cylinder. I would bet the bore diameters are different for our trucks also. |
http://67-72chevytrucks.com/vboard/s...30#post8909230 This is the same thread where 54blackhornet discussed his research at NAPA going into paper parts books to figure out the correct master cylinder. http://67-72chevytrucks.com/vboard/s...30#post8909230 |
2 Attachment(s)
I used this master on my Studebaker to go from manual drum to manual disc .
https://www.speedwaymotors.com/GM-Co...ore,51673.html Some pictures I used an inline portioning valve for the rear . |
yep, 2nd the motion that you have a deep hole non-power brake mc - good news!
3 Attachment(s)
and a few hours and a bucket of sweat later she's on
hey bro, hey bro, what kinda carburetor are you running is that one of them organic Holley Carter Rochester Quadrajet Edelbrocks?
I think they're called Quadrazaps.
