Hidden hitch help
Got a 89 c2500 swapped to dually running a Rollpan and need a hidden hitch. What brand or part numbers are you guys running I’m getting different info when I search some saying it will work then some saying not for 2500 only 1500 trucks some saying 3500 only just curious thank you for the information guys ahead of time
Re: Hidden hitch help
For my '99 C2500, I purchased a standard HD CURT brand ClassV hitch that's modular in construction. There's the main receiver beam that bolts to the frame rail mounting flanges. The standard version is just like most/many hitches & located the receiver just under the bumper. But since it's modular, my plan is to eventually make my own frame mounting flanges so that the receiver beam is located higher (behind my license plate) where I want it. I haven't done it yet. I opted to bolt it on 'as-is' for now until I'm ready to align things for the hidden set-up once I'm ready to build the rear under-bed portion of the exhaust. With 7-8" of rear drop, it's tricky running the pipes all the way out to the far corners while still having access to the hitch/mounting hardware if desired. |
