Connector help
Any idea what this plugs into? It is in the transmission harness, But I can't seem to locate the other end
Re: Connector help
Wire colors? Is it 4WD? Output speed sensor for 4WD lt blu, and Green/yellow.
It looks like the tail light connector, Green, brown, yellow, black. |
Re: Connector help
1998 c1500 2wd. Colors are hard to make out. Itis in the harness right above the transmission.
Re: Connector help
looks like an 02 sensor plug?
Re: Connector help
It turns out that it was not used. I am guessing it was for a transfer case. I noticed this as the plug has a dust cover that exposes the connections.
