1980 Silverado C10 “Big 10”
I just picked up this 1980 Chevy Silverado C10 from Fairbanks, Alaska for $800! It was a beautiful trip and well worth the 600 miles around to bring it back home. It is a factory Big 10 package, the engine is missing, but still has the TH350, 12 bolt rear axle, and was optioned with power windows, power door locks, sliding rear window, A/C, power steering, power brakes, and what appears to be the deluxe interior. It has factory rally wheels with only 3 trim rings missing, and two tone paint with exterior body trim. It also has an aftermarket rear bumper still in pretty good shape. Despite the options, this thing sat outside with the windows open for quite a number of years. However, it seems to have faired pretty well and there’s not too much rust, mostly just some large dents I’m hoping to get smoothed out. It’s missing the title, so until I get that bonded I won’t be doing too much to it other than cleanup and collecting parts, but I do have quite a lot sitting around that will end up being used here.
Ultimate plans are a stock-ish Vortec 350 that’s sitting in my shop, and one of the two TH350’s I have, most likely the one that’s already in the truck. I will also probably do a 4.5”/6” drop, and undecided on using the rally wheels or going with an aftermarket set. I have a 73/74 grille kicking around the shop I might throw in as well. Other than that, just clean it up and drive it. The drive up! Left the house at 4:00 am https://i.postimg.cc/K8QFXj74/IMG-8270.jpg This is the picture from the ad. https://i.postimg.cc/3JXYBndX/IMG-8258.jpg Lookin’ a little sad there buddy. Let’s get you home. https://i.postimg.cc/1zjQtdjQ/IMG-8271.jpg All loaded up! https://i.postimg.cc/4yzkWxNf/IMG-8274.jpg Beautiful views the whole way! https://i.postimg.cc/1R6QmJ0k/IMG-8276.jpg https://i.postimg.cc/MKmJRHFt/IMG-8278.jpg Got home and started cleaning it up! https://i.postimg.cc/T3k87SGD/IMG-8279.jpg https://i.postimg.cc/9fS6V7DX/IMG-8280.jpg Set the hood back on. Cleaned up pretty well! https://i.postimg.cc/NFvZ2v8W/IMG-8281.jpg https://i.postimg.cc/Kj7wnpJ4/IMG-8282.jpg Going to hit the interior next. Half tempted to find a bucket/console set from a suburban. https://i.postimg.cc/rFcv8cw4/IMG-8283.jpg BIG 10! https://i.postimg.cc/x11hzRHT/IMG-8284.jpg |
Re: 1980 Silverado C10 “Big 10”
Here’s some of the new parts I have sitting around that will end up on this engine.
Milodon Anti-climb shelf for the oil pan and ARP Vortec intake bolts https://i.postimg.cc/LsgGv3Tk/IMG-8297.jpg Holley aluminum Vortec timing cover with no sensor hole https://i.postimg.cc/tT0wcnSK/IMG-8296.jpg Cloyes True Roller single row timing set https://i.postimg.cc/mDQJWZKt/IMG-8295.jpg Melling M55HV high volume pump and drive shaft https://i.postimg.cc/FzNqr5QG/IMG-8294.jpg Elgin 1.6 ratio rockers https://i.postimg.cc/GtKf97LR/IMG-8293.jpg LS3 beehive springs with Comp retainers https://i.postimg.cc/XNkm2JwP/IMG-8292.jpg ARP main bolts for 4 bolt main blocks https://i.postimg.cc/4N4MjgPx/IMG-8291.jpg OEM LS7 lifters https://i.postimg.cc/X72hbz1c/IMG-8290.jpg Weiand Vortec carb conversion intake https://i.postimg.cc/mgtn2y0x/IMG-8289.jpg |
This was originally purchased for another project, but I found a better block I wanted to start off with instead, so this engine will now be used for the C10.
Donor rig was a 2000 Express Van https://i.postimg.cc/yNS8xsn1/IMG-6558.jpg Engine out! https://i.postimg.cc/90cmLT20/IMG-6560.jpg Engine separated from the transmission and heads removed https://i.postimg.cc/52bHHxwQ/IMG-7098.jpg https://i.postimg.cc/8PhJPFrV/IMG-7099.jpg On the stand. Oil was a little milky, so head or intake gaskets were done. https://i.postimg.cc/B6LtWtGk/IMG-7102.jpg Started teardown https://i.postimg.cc/zBY39J3D/IMG-7141.jpg https://i.postimg.cc/wv53zSsX/IMG-7142.jpg Completely stripped down. Everything looked serviceable other than some light scoring on the pistons. Off to the machine shop! https://i.postimg.cc/Wz2z1XMQ/IMG-7143.jpg |
Tinkered on it a little this weekend. Hooked a battery up to see if I could get the power windows to work. The switches seem functional, but I believe the motors are seized. There’s a little bit of life in her, though! :lol:
https://i.postimg.cc/Kv64B0dL/IMG-8320.jpg I also scored a bench seat for $100. It’s from a crew cab and non-folding, and the mounts will have to be swapped, but it’ll look better inside now. https://i.postimg.cc/wBHvb7xj/IMG-8361.jpg Vacuumed the interior and removed the carpet and padding. Found some rocker rust, but the floor seems to be pretty nice overall! https://i.postimg.cc/mrwDxBhN/IMG-8360.jpg Also wiped the interior down! https://i.postimg.cc/Hxvkxzwr/IMG-8363.jpg I picked up a full set of interior switches. Part of the title process says that the vehicle needs to be street legal, so all of the safety equipment needs to function, such as the horn, headlights, turn signals, brake lights, etc, so I’m hoping this solves a lot of issues right out of the gate. https://i.postimg.cc/D0WybG6B/IMG-8364.jpg |
Small change of powertrain plans, picked this up today! 1999 Express 2500 with a 5.7 Vortec and 4L80E for $250! Should be a good donor rig!
https://i.postimg.cc/rwXwFfBZ/IMG-8380.jpg |
I really need to get that winch mounted on the trainer. Hand cranking it up on there was a pain in the ass!
https://i.postimg.cc/8zmKkZdg/IMG-8388.jpg Wasted no time parting it out! https://i.postimg.cc/HLS6XjPS/IMG-8443.jpg Sawzall to the rescue! https://i.postimg.cc/bJs3T87q/IMG-8445.jpg Engine and trans out! https://i.postimg.cc/26MT9MYh/IMG-8448.jpg |
Post some pics please...
Engine and trans in the shop!
https://i.postimg.cc/R0HHB7Ky/IMG-8487.jpg https://i.postimg.cc/7YtGJsNj/IMG-8488.jpg |
Cool project, Im kinda curious how positive you are about it being a 1980? Since it doesn't seem to have the correct hood or grille setup for an 80. I know those things could have been swapped but I'm just curious what you're thoughts were.
It’s an 80 per the VIN and door tag. The hood, although close, isn’t the exact same color, and the front end has definitely been worked on since the valance is white. It’s getting a ‘73 grille though as soon as I get the mounting brackets from a buddy.
Okay that would make sense.
After I posted my reply I realized the truck does have the correct mirrors and has the fuel doors in the bed which would be correct. (I think fuel doors came out in 79? Someone can correct me if I'm wrong) |
