Core support rebuild
My core support is rotted away from under the battery, can you guys tell me if they're symmetrical in the bottom corners before I start trying to fabricate a new piece please? Thanks as always
Re: Core support rebuild
There are patch panels available. See the thread below.
https://67-72chevytrucks.com/vboard/...rt+patch+panel |
They are symmetrical.
Good luck, Rg |
I replaced the support on my 68 fitment was spot on . Wasn’t near as bad as yours if you want to retain the original you could use a repro as patch panels .
Like some others, I made mine from some leftover sheet metal I had laying around. This is an area not easily seen, so wasn't too worried about cosmetic appearance, and money saved and I could spend elsewhere on the truck.
You may want to consider the patch panel. It completes the difficult bends at the bottom. The rest may be flatter and easier to deal with. However, with out knowing your skills and resources my recommendation may be just that, a recommendation that is based on my skills.
Best of luck. |
Maybe figure out the dimensions of the patches needed. Maybe someone on here could cut them to size from a support offered on the parts page. Or someone with a semi usable one they have laying around. If not able to get all of them, you might get enough to make it easier to fabricate. Just an idle thought floating through my meager mind.
