Old 07-29-2007, 01:02 AM   #1
TYZ 67
TYZ 67's Avatar
67' Truck Build
Just thought I would start a thread on my build. Bought my truck about a month ago. Have it mostly stripped down minus the cab, bed and suspension. I will be starting with some of the body work first (patches, welding, etc...). Wish I could start with the suspension first, just don't have the $$$ to do so yet. I will be bagging it with a triangulated 4 link in the rear and I really like the C4 dropmember Porterbuilt has. Not sure if I am going to do 20's or 22's, haven't found to many pics of these trucks with 22's. If anyone has good pics please post. I am probably going with the Coys C5 polished or gun metal. Speaking of posting pictures how do you post them. It asks for a URL to post the picture. It won't let me post from my computer. I will post some pictures when I figure it out.
TYZ 67 is offline   Reply With Quote
Old 07-29-2007, 02:58 AM   #2
BurnoutNova
BurnoutNova's Avatar
Re: 67' Truck Build
you need to use a host for your pictures such as picturetrail... then post the url inside [img]....[/img]
BurnoutNova is offline   Reply With Quote
Old 07-29-2007, 03:41 AM   #3
CrashEd
72 chevy
CrashEd's Avatar
Re: 67' Truck Build
If you go to the [go advanced] post theres a paper clip that will let you put pictures up from your computer.
Ed
CrashEd is offline   Reply With Quote
Old 07-29-2007, 11:55 AM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: 67' Truck Build
IMO, there is no reason to run 22's
You can't see the difference, cuz it's just an inch bigger across & you have just that much less tire
I have 20's & wish they were 18's, but it's all a personal choice
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-29-2007, 02:10 PM   #5
bagged74
its just $$$$$
bagged74's Avatar
Re: 67' Truck Build
actually its 2 inches, and you can still have the same sidewall ratio as long as there is room.
22s can look good , but like Spray-bomb said its personal preference
bagged74 is offline   Reply With Quote
Old 07-29-2007, 05:56 PM   #6
TYZ 67
TYZ 67's Avatar
Re: 67' Truck Build
I'll probably go with 20's. What is the best way to do the front inner fender wells when bagged. I want my truck to sit about an inch or so off the ground when fully deflated. Is there a way to raise the stock fender wells? I will be raising the rear fender wells and bed. I would like to keep a semi classic look. By the way this site is great. Everyone is helpful and has great ideas. Thanks!
Old 07-29-2007, 10:31 PM   #7
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: 67' Truck Build
I said Across the wheel, thats 1 inch less tire
I don't have mine bagged quite yet, so I can't help you here except for this link
http://67-72chevytrucks.com/vboard/s...d.php?t=250756
Sinister
Killer
Old 07-29-2007, 10:36 PM   #8
bagged74
its just $$$$$
bagged74's Avatar
Re: 67' Truck Build
I still dont see how 22"-20"= 1" its 2 inches bigger no matter how you measure it. 1" on each side maybe, but not total. and its only less tire if you stay with the same overall diameter, which most people dont. Not trying to start a pissing match, but your info is kinda misleading to a guy who is asking for advice.
Old 07-30-2007, 01:18 AM   #9
Raguemoe
Junior Member
Raguemoe's Avatar
Re: 67' Truck Build
What??? I can see a difference!
Raguemoe is offline   Reply With Quote
Old 07-30-2007, 01:21 AM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: 67' Truck Build
Never mind, Whatever, Blah Blah Blah
Sinister
Killer
Old 07-30-2007, 01:46 AM   #11
bagged74
its just $$$$$
bagged74's Avatar
Re: 67' Truck Build
me too
Old 07-30-2007, 01:02 PM   #12
TYZ 67
TYZ 67's Avatar
Re: 67' Truck Build
Those trucks look sweet. I'll might go staggered that looks good. 20's in front will probably eliminate some clearance issues. Here's some pic of mine so far.
Attachment 287136
Hopefully these show up.
Old 07-30-2007, 01:09 PM   #13
TYZ 67
TYZ 67's Avatar
Re: 67' Truck Build
Raguemoe- Your truck looks sweet, couple of questions. What front suspension set up are you using, Dropmember or stock? Does it lay completely on the ground or just above. I want to be about an inch or so off. I like how your front wheels are straight up and down. Are the rear bags on the link bars? If so are the bars strong enough? Thanks for all you input so far. Where is Highland California at by the way?
Old 07-30-2007, 02:55 PM   #14
Joe67
67 is sold
Re: 67' Truck Build
Sounds like a sweet poject
I moved it to the BUILDS forum - run whatever wheel you like, that is what makes this hobby so great
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-03-2007, 08:29 PM   #15
TYZ 67
TYZ 67's Avatar
Re: 67' Truck Build
Well I decided not to go with the drop member, just to expensive for me. Plus I want to stay about an inch or so off the ground so there is no need for it. I might still try and incorporate a rack and pinion steering.
Old 08-03-2007, 09:00 PM   #16
Frizzle Fry
Frizzle Fry's Avatar
Re: 67' Truck Build
me too
Me too Nice project!
Frizzle Fry is offline   Reply With Quote
Old 08-03-2007, 09:19 PM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 67' Truck Build
When you say " stay about an inch or so off the ground " exactly what are you referring to? Are you talking about the frame, the rockers, or your crossmember?
In the event that you are not aware, the stock crossmember is the lowest point of your front suspension. If you lower your truck using bags and you modify the inner fenders the first thing to touch the ground will be your A-arm.
The pic below is my 82 Blazer, but it gives you an idea of what I mean....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-03-2007, 09:28 PM   #18
72 Cheyenne402
72 Cheyenne402's Avatar
Re: 67' Truck Build
This truck is sick man!!! I went with 18x8 and 20x9 in the rear. I almost went 20 & 22's I love your truck Raguemoe and can't wait to see more of it
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 08-04-2007, 01:36 AM   #19
Raguemoe
Junior Member
Raguemoe's Avatar
Re: 67' Truck Build
Stock front set-up w/Art control arms. Front crossmember is 1/2" off the ground (frame about 2 1/2"). I had a custom 3-link installed in the rear. Highland is 40 miles from Orange County. Just below Big Bear! More pics
Old 08-05-2007, 11:08 PM   #20
TYZ 67
TYZ 67's Avatar
Re: 67' Truck Build
N2Trux- I want the lowest part of the truck about 1" off. I had a buddy who's truck layed frame but he also had a bag blow out while driving. I don't want it to slam on the ground(frame will be powder coated) if that were to ever happen. I am also going to use the ART arms.
Raguemoe- Thanks for the info. Like the firewall. Do you have to modify the inner front fenders or do the wheels not touch? I'll post some more pics when I get some more visible progress.
Old 08-06-2007, 06:59 AM   #21
Raguemoe
Junior Member
Raguemoe's Avatar
Re: 67' Truck Build
Custom fender wells!
Old 08-10-2007, 08:36 PM   #22
TYZ 67
TYZ 67's Avatar
Re: 67' Truck Build
Raguemoe you truck is sweet! Can't wait till mine is that far along. What hood hinges are those. Custom fenders look great. I may do custom but I think I might try and keep the original for a semi classic look.
Old 08-11-2007, 03:56 AM   #23
Raguemoe
Junior Member
Raguemoe's Avatar
Re: 67' Truck Build
Fenders are made from trailer fenders and hinges are from a Mercedez car.
Old 08-11-2007, 04:54 PM   #24
PBFAB.COM
PBFAB.COM's Avatar
Re: 67' Truck Build
When combining the Dropmember with a stock spindle and a 27" tall tire, the frame-rail will set just under 2" off the ground when fully deflated. The main advantages of the Dropmember are the crossmember to ground clearance, and rack and pinion steering. It's not in everybody's budget, but it also isn't just for the guys who want to "lay frame" on 22's.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 08-12-2007, 02:33 PM   #25
TYZ 67
TYZ 67's Avatar
Re: 67' Truck Build
Porterbuilt- I love your dropmember. I thought one of the main reasons to use the drop member was to lay frame. I did forget that was with drop spindles. I also know it has many other advantages. I may still think about getting one, just have to decide how much I really want to spend. About how much is a complete setup minus the drop spindles. What brake setup is used. Sorry for all the questions. Thanks Tyler.
PS: I have you site on my favorites and the rendered picture of your "Shop Truck" on my background. Didn't mean to bash your product if that is what it sounded like.
