04-09-2017, 08:30 PM | #1 |
600 CFM on a LS2?
Hey they,
I have a 2008 LS2 engine off a Trailblazer SS and I'm wondering if I can put a 600 CFM Edelbrock w/elect choke on it. The holley DP that is on it is junk, and I'm looking for a quick and dirty carb for this, my local autoparts store has on one on the shelf (shocking!) Is 600 CFM too small? thanks! Nick |
04-09-2017, 10:44 PM | #2 |
Fabricate till you "puke"
Re: 600 CFM on a LS2?
The 600 Eddy, works fine on my stock 5.3....if you are street , I would say use it. More power/strip fun, I would go with a Quik fuel carb, in the 650- 750 cfm range. my bro has a DP 650, on a 383 S-10. The truck is a solid 12.5 ride ...out of the box, no tuning? Nice carb...Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-09-2017, 10:45 PM | #3 |
I should have mentioned: 4x4
backed by a th350 mild torque-y cam |
04-11-2017, 08:25 PM | #4 |
Understand, that the edelbrock carb, likes no more than 5 psi on fuel psi Not a race carb...Quik fuel/Holley, would be my choice Let the rest of the boys play.....longhorn
04-11-2017, 10:00 PM | #5 |
What he^^^ said. I personally would skip the edelbrock because they can be a finnicky pain in the @ss. You will get better performance out of holley street avenger. Quick fuel or Pro form would be my choice. Vacuum secondaries in a heavy truck with a mild engine will yield the best results.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
04-12-2017, 02:22 AM | #6 |
You know, I did some digging around and ended up with a Holley 670.
The carb on there now is a Holley, we'll find out tomorrow if I did the right thing. I'm a Q-jet man at heart, but I'm old enough to know I should try new things... If successful I'll post some burnout pics! |
04-12-2017, 12:37 PM | #7 |
You made a good choice. That carb will work great for your application.
04-13-2017, 10:02 PM | #8 | |
