08-16-2019, 03:27 PM | #1 |
manual or boosted brake question
well Iam at the point for a brake system ,I do like the feel of power brakes but was curious if I went with a complete manuel disc set up from wilwood 4 piston calipers and master cylinder. how would the pedal feel compared to a power system? Iam running a bbc 650hp with a t56 if needed to know. just dont want to spend all this money and then hate Manuel set up, my biggest worry is the amount of pedal effort needed, any advise is appreciated
08-16-2019, 08:34 PM | #2 |
Re: manual or boosted brake question
If there's one thing I've learned over the years it's that pedal feel is very subjective. In general, brake systems set up to require 60-70 lbs of force at the pedal for average stopping get the fewest complaints. But the amount of pedal pressure required for fast stops and the amount of control required to apply the brakes without lockup is reported very differently between drivers.
My suggestion is very general. If you plan to keep the truck, and if you are younger than 40, build a brake system that does not require large amounts of force to stop fast or often. As you age you will find that the "not so bad" brakes of yesterday are a bit of a PITA today. As far as the Wilwood setup goes, they have some exceptional engineers that can likely help calculate how much effort at the pedal is required to stop your truck using their brakes. It is possible for an average person to make well educated guesses and some rough calculations but I think you're best off to speak to Wilwood to get their input first. |
08-17-2019, 09:54 AM | #3 | |
08-17-2019, 10:20 AM | #4 |
A BBC with 650 hp is likely to have a cam that produces a weak vacuum signal to a power brake booster.
I think a hydroboost would be a good solution if you have power steering and you have a place to put it. |
08-17-2019, 11:01 AM | #5 |
yes true. being a Manuel transmission It might do alright... If not then I will be adding a hydroboost on it
